How often should I start my truck?
Discussion in 'Ask An Owner Operator' started by ready2truck, Jan 1, 2021.
  1. ready2truck
    ready2truck Medium Load Member
    301
    351
    Oct 27, 2020
    If I take month or more off how often should I start my truck and for how long? APU keeps batteries charged and coolant temp up in the winter.
    Trucker61016 Thanks this.
  3. Tb0n3
    Tb0n3 Road Train Member
    4,278
    8,194
    Oct 5, 2012
    Earth
    For a month? Might as well just disconnect the batteries and leave it cold. Seems like a waste of fuel to keep it warm.
  4. 86scotty
    86scotty Road Train Member
    4,373
    11,589
    Aug 27, 2017
    Appalachia
    I start mine every week or so when I'm off. I think it's just paranoia though. I agree with above, if I was taking a solid month off I wouldn't leave the APU on but I would still probably start it up for 30 minutes or so every week and let it run a heat cycle. Once again, probably not needed but just paranoia.
    My inverter has a 3 stage charger with pass through for the AC plugs in the sleeper so I just plug mine in wen I'm home for more than a day and it keeps the batteries charged. I also run a little plug in heater inside in the winter when I'm home so my water system doesn't freeze, not to mention all the food and drinks stored in there.
  5. abyliks
    abyliks Road Train Member
    3,742
    8,691
    May 2, 2010
    ludlow MA
    Start it before you go back to work, we have trucks that will sit a couple months with out getting touched
  6. AModelCat
    154,213
    I'd just park it, disconnect the batteries and leave it alone. Go out to it a day or 2 before you need it and start it then.
    tommymonza, Tb0n3, Shawn2130 and 3 others Thank this.
  7. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    Started my truck and reefer yesterday for the first time in a week. Other than low air in the tanks, it didn't seem to mind the long wait.
  8. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    Where do you live ? cold zone?
    Doesn't make sense to keep the APU running , it's a fire hazard , if you can't keep on eye on the truck. I'm parked since dec 22nd , off until 14th of January. and started once only two days ago when the temp was 40F/6 Celsius here in southern Ontario, let it run for 30 min.
    I use 0w40rottela T6 synthetic oil, treated the fuel with a bottle of Kleen-Flo diesel conditioner, just in case, but i don't think was needed, mild winter here so far. This is important if you start it, better in a warmer day or in the afternoon when temp rises above freezing . If i have to start in cold , (i don't have electricity in my parking place), i bring my Yamaha power generator and plug the block heater , even the batteries ,it has battery charger ports/cables. I keep it plugged for about one hour, turn the key on watch the coolant /oil temp before and after, or touch the side of engine block , feels warmer.
  9. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    During the covid shutdown we parked all our trucks in the barn. Two months later when we were allowed to work again 1-2 of the 45 trucks needed a jump. Every other one fired right up like the break didn't happen.
  10. Brandonpdx
    Brandonpdx Road Train Member
    4,184
    3,971
    Dec 27, 2007
    Elkhart, IN
    That's not long enough to worry about if you disconnect the batteries.
    God prefers Diesels Thanks this.
  11. Studebaker Hawk
    Studebaker Hawk Road Train Member
    2,962
    9,546
    Oct 18, 2010
    NW Indiana
    If it is going to down for more than a week, disconnect the batteries if it has an electrical parasitic load situation. Some trucks are worse than others.
    If you are going to start it, don't just let it sit and idle for a while, you really should drive it, 20 or more miles to let everything warm up completely. Otherwise, disconnect and leave it completely dormant.
    After dealing with alternately storing and driving old cars for 50 years, I have found it is best to prep it for storage, most manufacturers have a procedure, and leave it alone.
