How NOT to fill your fuel tanks
Discussion in 'Experienced Truckers' Advice' started by Lepton1, Sep 1, 2018.
  1. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    You should NOT fill your tanks right up to the brim of the cap! Diesel fuel systems require about 5-10% air at the top of the tanks for fuel return. It builds pressure in the tank.
    I was just parked next to a driver leaking diesel out of the cap. I alerted him to the problem, he got his gloves on and undid the cap and at least a gallon of diesel spilled out (in addition to the gallons already spilled at a rate of about a gallon every few minutes).
    I once witness a mega carrier driver topping his tanks so much at the fuel island he spilled a gallon or two making sure he got the entire benefit of his fill up, giggling as fuel spilled on the ground.
    Guess what? You get caught spilling fuel like that and it becomes a hazmat issue. It can get expensive in a hurry.
    You should NEVER fill your tanks past the point the fuel is higher than the bottom of the short tube sticking down from the cap. READ THE INSTRUCTIONS NEAR THE FUEL CAP. IT SAYS YOU CANNOT FILL MORE THAN 95% CAPACITY OF YOUR TANKS.
    That driver I just talked to rolled on out, tracking diesel fuel off his tires. Obviously he doesn't own the truck, or he would pay attention to this ####. There's a puddle of a few gallons flowing under my truck. I'm moving parking spots to avoid the problem. I alerted the truck stop so they can start cleanup.
  3. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Also, diesel will expand as it heats up, especially if there is a fuel return from the motor (like my CAT has). If the cap has any sort of leak, putting too much cool diesel in will have it spill out the leaky cap after it warms up. It has happened to me.
    Oxbow, stwik, Grubby and 2 others Thank this.
  4. ebill45
    ebill45 Light Load Member
    167
    105
    Oct 11, 2011
    dalton ga
    its Impossible to fill the tank 100 percent through the fill cap.
  5. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    you must not have ever bought your own fuel. i have done this since i started driving.
    flood and Trucking in Tennessee Thank this.
  6. mover man
    mover man Road Train Member
    1,698
    1,801
    Feb 21, 2010
    Of I'm gonna drive 2-300 miles with out stopping. I fill it all the way up of as much as I want to. The tank vents itself
    Rideandrepair, Grouch and buddyd157 Thank this.
  7. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    I stuff mine everyday and I buy the fuel. If I Fuel at the end of the day and shut truck off. The fuel that was left over (hot) will cool down decreasing in volume . And if I fuel and go every 6 miles a gallon is gone......
    My tanks are vented and the only time I’ve seen a problem is if you stuff them and park on the side of a hill.
    My guess is that guys truck was returning more fuel to one side........
  8. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    My new truck, I fill it as much as I can get in there. None lost out the cap or vent hose. My old classic I'm pretty sure would return more to right side tank, it would leak out the cap if filled more than about 80%. So that's about as high as I'd usually fill it. That's not to say all peterbilts are the same as mine or freightliners as my old unit. All trucks are a little different.
    speedyk and Lepton1 Thank this.
  9. bryan21384
    bryan21384 Road Train Member
    14,493
    31,005
    Sep 18, 2009
    Memphis, TN
    I always get what I need. I havent filled up my truck in forever. It's somewhere between 1/2 and 3/4 tank. That's enough to cover most of the ground to Clear Lake, IA once I leave the house in the morning
  10. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    If a problem somehow develops in the crossover line (equalizer), you’re going to end up with fuel coming out somewhere at the top, on the side the return fuel goes into, no matter what level you fill to.
    Bean Jr., flood and buzzarddriver Thank this.
  11. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    I can't look at the moment, but I don't believe that filler caps are located at the highest point on the tank so this can't happen.There is always an air space at the top to allow for expansion.
    Bean Jr., snowlauncher and Lepton1 Thank this.
