How much you can load on 53' dry van with single axle tractor and be legal?
Discussion in 'Experienced Truckers' Advice' started by Verdel, Oct 25, 2014.
  1. Verdel
    Verdel Medium Load Member
    596
    135
    Oct 26, 2013
    I have seen some single axle tractors with low miles and pretty good price, so I was just wandering, can I get 40k lbs load on a 53' dry van and still be legal?
  3. The Challenger
    The Challenger Kinghunter
    7,127
    3,367
    Dec 22, 2007
    East Central FL
    I believe the limit is 64K total w single axle tractor. Not too sure but maybe someone else with more experience can expand on it.
    KH
  4. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    12k or whatever the lowest rating is on front axle or tires. 20 k drives 34k on trailer or 40k with 10'1 spread 64 k is most common BUT the issue becomes loading trailer so drive axle isn't over loaded if your loading over 30 k on a regular basis go tandems and not worry over axle fines and csa points will kill the fuel milage savings .. Another thing is shippers won't want to pay for a 53 ft trailer that they need to single out first 3 or 4 rows IMO
  5. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Just plan on adding a tag axel to your cheap single axel truck and start loading your wagon to the max?
  6. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Gross is still 80K
    You can only put 20k on the single trailer axle. 12 in steers, 34 on truck duals, 20 on trailer limits you to 66K. Some states allow more on steers, but your still gonna be pretty limited.
  7. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    12000 steers, 20000 drives and 34000 on the tandms 66000 less the tare. The only way for single screw tractor to workout is pulling doubles.
  8. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    my bad, i miss read....
    12 steer, 20 drive, 34 on trailer......but, if you get a split axle trailer (10 foot between each wheel) you could load 40 on trailer.
  9. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Up to the maximum gross weight you have it licensed for and whatever your maximum combined legal axle weights is in your state(s), [whichever is less]. But this is all dependent on what state(s) you plan to operate in as legal max weights vary considerably in some states. There is also the maximum gross weight the manufacturer has stated the tractor can manage (probably stated inside the driver door panel). Not all single axle tractors are equal.
    40k inside a 53 foot dry van and be legal? It's doubtful you could keep it light enough on both ends to max out whatever is available to you, and meet any length requirements that may or may not also be applicable in your state(s). Few shippers (who ship that heavy) will want to see a dry van that can not handle at least 43k-44k lbs
  10. RubberDuck198
    RubberDuck198 Light Load Member
    216
    150
    Mar 16, 2014
    Lemme check my atlas
    12,000 steers, 20,000 drive, 34,000 trailer tandem making your GVWR 66,000 lbs. Subtract your curb weight + fuel from your GVWR to determine how much you can load.
    There should be a placard on the frame of your drivers side door telling you the manufacturer specifications.
  11. RubberDuck198
    216
    150
    Mar 16, 2014
    Gross changes based on your axle configuration. 80,000 lbs is by no means a universal number.
    G13Tomcat Thanks this.
