How much will it cost me to rebuild a 13 sp fuller transmission?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Crazy Alex, May 5, 2015.
  1. Crazy Alex
    Crazy Alex Light Load Member
    161
    46
    Dec 1, 2012
    Here n there
    2002 Volvo 770
    ISX 450
    1350000 miles
    Took a oil sample from transmission,came back as "Severe".
    The only problem with it is that it kinda jerks when you in gauge…no problem 1,2,3,4,5…even 6,7,8 aren't that bad,but 11,12 and 13 you need to step gently on the
    accelerator after you shift,otherwise it jerks/kicks…driveshaft was checked,yoke nuts tightened-no change.
    So I think the transitions needs to be looked at
    ANY IDEA HOW MUCH IT MIGHT COST ME? AND HOW LONG ?
  3. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    That is the question to ask after the mechanic it is out and torn down, anything else is purely speculation. If you want to plan, plan on the cost of a replacement, anything less is only good news. :biggrin_25525:
    blade Thanks this.
  4. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    depends on what parts might be broken,,a great trans shop in the west is called Mason Diesel Service in Aurora, Ut next to Salina Ut off I-70,,they do great work and have parts in stock,,they have a very reasonable labor rate too. Can't beat their prices or the quality of there work.
  5. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    If an oil sample comes back severe just change the oil. If your splits on the high gears aren't working well, quit using them, and just drive it like a nine speed.
    CruisingAlong and Heavyd Thank this.
  6. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Yep, just change the oil. Transmission oil is changed at about 500K miles, so any analysis results will show "severe". The rest is just shifting technique. I think rebuilding or replacing your transmission is just money wasted at this point.
    wore out Thanks this.
  7. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    on 13 speeds usually just the back half needs to be rebuilt but with those miles .........
    if the whole tranny needs rebuilding just get a factory reman which are about $3800 with a 2 year warranty + install +clutch
  8. Crazy Alex
    161
    46
    Dec 1, 2012
    Here n there
    Where do I get the factory reman?
  9. wore out
    wore out Numbered Classic
    15,319
    184,946
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Passed over the advise of one of the better technicians on the forum to jump at the expensive option. Whatever you do doesn't matter to me but I would ease up a little and take a breath. That tranny may have not a thing really wrong with it. Even if it's getting some wear it may last as long as the rest of the truck. Dropping 5 to 6k minimum to go reman isn't going to make it worth any more or less.
    icsheeple, rollin coal and Heavyd Thank this.
  10. Crazy Alex
    161
    46
    Dec 1, 2012
    Here n there
    I am looking at all the options…but better to know where to get a replasement part in case I get stuck somewhere on the road and have to ship it in…right?
  11. BASARAB
    BASARAB Light Load Member
    201
    89
    Sep 4, 2014
    Warren, mi
    About 3.5k at an Indy shop
