I'm thinking about getting a hook ladder so I can climb onto my trailer with a foldable chair to hang out when it's nice out, but I would like to know the weight rating for a trailer roof before I do that.
How much weight does the roof of a trailer hold?
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by BillyBobFrank, Aug 22, 2023.
Page 1 of 4
Flat Earth Trucker and austinmike Thank this.
Not a good idea. Just thin fiberglass panels and aluminum braces don't hold much.
Flat Earth Trucker, austinmike, gentleroger and 4 others Thank this. -
buddyd157, BillyBobFrank, Flat Earth Trucker and 8 others Thank this.
I wouldn't sit up there myself but if you wanted to you should be fine unless your chair has pegs for legs instead of a bar that would sit along the ground/trailer roof and you don't weigh half a ton. Think how much snow is up there sometimes, I've never heard of a trailer roof caving in due to snow. Might be a bit warm on the feet..
bzinger Thanks this. -
LoneRanger, Flat Earth Trucker, bzinger and 2 others Thank this.
Most roofs are flimsy plus dirty as heck . Bird droppings soot dirt etc build up over time ..
Savor the Flavor, gentleroger, bzinger and 1 other person Thank this. -
Additionally, should you choose to do it anyway, disperse your weight over a greater contact area of the trailer and more importantly, take your ladder with you. If you don't take your ladder or otherwise secure it to the trailer, another driver will walk off with it, leaving you stuck on the roof.
Better yet, pull a flatbed and you will have a sturdy deck that's low enough to get on without the need for a ladder, at least while empty or with a partial load on the deck.Speed_Drums, Flat Earth Trucker, bzinger and 3 others Thank this. -
LoneRanger, Speed_Drums, Coffey and 8 others Thank this.
Where I am, OH&S requires tie off at heights greater than 10 feet. That'd be considered a safety violation here if someone reported it. Your rules may vary.
Albertaflatbed, Magoo1968, tscottme and 2 others Thank this. -
You can most likely find a spot on a nice day with your foldable chair then the top of your trailer I would guess.
Page 1 of 4
