2007 Kenworth T800, cab and sleeper ac.
System sometimes works, sometimes, it no worky. Will peg high pressure gauge, and show about 10 lbs on the low side then compressor will lose power- (apparently binary switch is doing it's job); then it will work fine for awhile, numbers are good on gauges. Trouble shooting guide, and company mechanic both say to replace the expansion valve, but cannot find the info tag that states how much refrigerant the system holds. Compressor is the Sandorn (?), round one, think it is called a rotary vane?
If anyone knows the amount, and/or where that info tag is located; (it may be on my truck, and I'm just not looking in the right place.), would appreciate it.
Yes,
I'm also replacing the drier/filter, yes I have the gauges and vacuum pump, just don't know how much R-134 to go back with. Also, should I add any compressor oil when doing the re-charge?
Thanks in advance!!
How much R-134 to put in?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by droy, Mar 14, 2012.
