How much PSI are you running in your tires?
Discussion in 'Ask An Owner Operator' started by Phantom307, Sep 16, 2020.
  1. Phantom307
    Phantom307 Light Load Member
    222
    210
    Jul 5, 2019
    Cheyenne
    I don't haul heavy freight everything I do is under 80,000 pounds. I have been told to run my tires at 100 PSI a while back and that is what I have always gone by. I recently read an article that improper inflation pressure on the tires is one of the highest expenses on a trucking company that can be avoided due to excessive wear and lowered fuel economy. But they never mentioned the proper inflation levels that could help avoid this cost, so it got me curious. Id would appreciate if someone could provide some reputable information.
  3. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    Depends on the tire, but usually I run 120 psi cold in my tires, I dont normally check actual air pressure on a hot tire, won't be accurate.
  4. blairandgretchen
    13,212
    70,208
    Dec 9, 2011
    South west Missouri
    120 steers, 110 all others.
    Wespipes, stwik, drvrtech77 and 6 others Thank this.
  5. Phantom307
    222
    210
    Jul 5, 2019
    Cheyenne
    thanks for your input, is there any reason why you run it at that pressure?
  6. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    I have found that I get decent tire wear, also I run mostly out west here in the desert and over the years never had a problem. Low tire pressure will make your tire run hot, resulting in blowouts.
    John E., blacklabel, Shawn2130 and 3 others Thank this.
  7. Long FLD
    Long FLD Road Train Member
    11,354
    45,708
    Mar 4, 2015
    120 on steers and 110 in my drives also.
  8. Rideandrepair
    17,202
    55,794
    Aug 8, 2015
    105 on Truck, 110 on Trailer. A little more, just before winter. Since the temp drop will cause a pressure loss.
  9. Midwest Trucker
    5,871
    21,124
    Aug 31, 2018
    100 psi but maybe I’m behind the times as well. I was always told 100 in steers and 95 in drives but that came from an old timer so maybe things have changed.
  10. Long FLD
    11,354
    45,708
    Mar 4, 2015
    If you’re carrying max weight on your steers then they should be aired up to what the sidewall says for max load. That’s usually 110 or 120.
  11. 401-Alex
    401-Alex Light Load Member
    258
    278
    Nov 25, 2013
    401
    I do 110 cold all around. Trailer has auto inflation system set at factory@100 thought it was ok till the shoulders on my tires were worn adjusted it it as close to 110 its 112 . ive tried 100 on steer and drive ive tried 120 110 on 14 ply seems best to me
  12. Phantom307
    222
    210
    Jul 5, 2019
    Cheyenne
    thanks all, i am going to try upping it to 105 and see if i do better then try 110 with the next set of tires and see how that works out.
    Also, is anyone using the tire inflation systems like crossfire/catseye that keep tire pressure equalized between dual tires? I just got some after reading that tires with uneven PSI result in tire getting dragged something like 14 feet per mile i hope it will extend my tire life
