So there is a grease fitting under my transmission, but every time I grease it I don’t know when to stop as I don’t see any grease coming out anywhere. I am guessing I have to remove the small plate that the grease fitting is sticking out of? This is on a DD15 engine.
How much grease to pump into the transmission?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Jan 15, 2019.
There should be 3 grease fittings. 1 on the bottom of the release bearing (the one on the short whip hose) and 1 on each side of the bellhousing, about half way up. The ones on the side are for the cross shaft bushings. I normally give all three about 2-4 shots every other week or so. Too much grease is bad because you can contaminate the clutch lining or the clutch brake lining.
AModelCat. Is the bottom one for the clutch brake?
The bottom one is for the release bearing.
A5¢ Thanks this. -
