How much fuel do you really have left when that fuel light comes on
Discussion in 'Questions From New Drivers' started by DAX_, Mar 5, 2020.
  1. DAX_
    DAX_ Medium Load Member
    557
    415
    Sep 4, 2017
    If it makes any difference I have a 2020 freightliner
  3. JonJon78
    JonJon78 Road Train Member
    7,041
    37,547
    Jul 1, 2018
    What size tanks?
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Every truck is different. Here's an idea, look in your tanks with a flashlight and see.!
  5. Hazmat Cat
    Hazmat Cat Medium Load Member
    636
    1,778
    Oct 18, 2019
    I don’t wanna find out
  6. Opus
    114,710
    not much......maybe 20 gallons at most
  7. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    the road less travelled
    You don't want to lose prime, so when that low fuel light comes on, best start planning on where to stop.
    As one driver told me a long time ago, better to fill too soon than to need fuel brought to the truck.
    2018 with 2 100 gallon tanks, the light comes on at 140 gallons to fill. Much over 160, you're lucky you didn't have to walk, but this one loses prime more easily than most others I have driven.
    Still will go around a thousand miles on a fill if I haven't idled too much. Maybe 1100.
    MACK E-6 and DAX_ Thank this.
  8. Moose1958
    Moose1958 Road Train Member
    15,090
    33,171
    Dec 17, 2010
    Williesburg, Virignia
    I would also add you really don't want to get fuel levels that low. To start with if you have an APU those fuel reeds are designed to not go all the way to the bottom. This is to avoid getting trash into the APU. Like the previous comment, you don't want to lose prime and take the risk of sucking trash up into the filters. This also applies to reefers too. If you run one out of reefer fuel it's almost a certainty you will have to call out a mechanic to change that fuel filter. Don't do it!
    PE_T Thanks this.
  9. Lostmykey
    Lostmykey Medium Load Member
    386
    521
    Oct 6, 2019
    2020 cascadia; could only put in 112 gallons when the light came on. 160gal is supposed to be the capacity
  10. PE_T
    PE_T Road Train Member
    I have two 100 gal cylinder tanks, and I’ve used up to 170 gallons. In my truck, I have up to 50 miles to go once the needle hits the bottom of the fuel gauge. However, you do not want to do this as you risk sucking in dirty fuel sitting in the bottom of the tanks. I have never run out of fuel, and I regularly fill up my tanks to about 160 gal.
    I remember reading a chart where it mentioned that 6 gallons are “unusable fuel” sitting in the bottom of a 100 gal tank. Also, 5% of 100 gal cannot be filled with fuel on cylinder tanks. Rectangle tanks can take in more fuel, but you’re supposed to leave 5% of empty space for safety reasons.
  11. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,521
    May 28, 2015
    I have two 150s. The fuel light comes on and I top off and it holds 230ish.
    Tells me that there is 70 still in there.
    Problem is that I don't know where the pickup is set and I ain't gonna test it.
    I wish I did know.
