How much can legally hang over the side of a flatbed?
Discussion in 'Flatbed Trucking Forum' started by myrt, Mar 16, 2015.
  1. myrt
    myrt Bobtail Member
    5
    Sumrall, MS
    My old trailer was a 48 x 102 so I never had any overhang, but now I have a different trailer that is 48 X 96. There is about an inch or so hanging off each side. Just wondered what the DOT says is legal. Anybody know?
    I have heard you can have 4' overhang on the back, but haven't ever heard about hanging off the sides.
  3. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,842
    Jul 28, 2011
    Glasco,Ks.
    As long as it's secure no one should bother you until you are over 102, even on a 102 trailer some things will usually be overlooked, like tire bulge, your strap winches, etc.
  4. Allow Me.
    10,642
    12,097
    May 28, 2009
    Rancho Mirage, Ca.
    Yeah, width allowed is 102". If over, you can be cited. Your mirrors are excepted.
  5. myrt
    myrt Bobtail Member
    5
    Sumrall, MS
    OK, I should be good then. Thanks!
  6. nightgunner
    nightgunner Road Train Member
    2,112
    2,799
    Jul 23, 2013
    Cedar Rapids, IA
    Typically "safety" gear (mirrors, securement devices, etc.) is overlooked. However, There "Tire squish" on wheeled equipment has been counted against the driver from time to time. Be nice to Mr. inspector and more often than not they will overlook it.
  7. nikmirbre
    nikmirbre Road Train Member
    5,371
    9,537
    Jul 27, 2011
    High Point NC
    Your binders and securement equipment are allowed 2 inches...if you have a 48x96 trailer, your still allowed up to 102.....
  8. macavoy
    macavoy Road Train Member
    1,092
    1,956
    Jan 3, 2011
    Houston, Tx
    I don't know if I'm right but I thought securement devices were allowed 3".
    catalinaflyer and MJ1657 Thank this.
  9. catalinaflyer
    catalinaflyer Road Train Member
    2,278
    20,065
    Oct 23, 2008
    Wichita, KS
    I do believe you are correct, I know we're allowed 108" wide on our Quick-Draw trailer because the extra 6" is covered under the securement/load covering laws. We pull them in 49 states and all of Canada without an issue.
    SnakeSkinssssss Thanks this.
  10. nikmirbre
    5,371
    9,537
    Jul 27, 2011
    High Point NC
    Ok sorry for the mis-info------it may be 3
  11. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    CFR Title 23 - Highways
    § 658.16 Exclusions from length and width determinations.
    (a) Vehicle components not excluded by law or regulation shall be included in the measurement of the length and width of commercial motor vehicles.
    (b) The following shall be excluded from either the measured length or width of commercial motor vehicles, as applicable:
    (1) Rear view mirrors, turn signal lamps, handholds for cab entry/egress, splash and spray suppressant devices, load induced tire bulge;
    (2) All non-property-carrying devices, or components thereof—
    (i) At the front of a semitrailer or trailer, or
    (ii) That do not extend more than 3 inches beyond each side or the rear of the vehicle, or
    (iii) That do not extend more than 24 inches beyond the rear of the vehicle and are needed for loading or unloading, or
    (vi) Listed in appendix D to this part;​
    (3) Resilient bumpers that do not extend more than 6 inches beyond the front or rear of the vehicle;
    (4) Aerodynamic devices that extend a maximum of 5 feet beyond the rear of the vehicle, provided such devices have neither the strength, rigidity nor mass to damage a vehicle, or injure a passenger in a vehicle, that strikes a trailer so equipped from the rear, and provided also that they do not obscure tail lamps, turn signals, marker lamps, identification lamps, or any other required safety devices, such as hazardous materials placards or conspicuity markings; and
    (5) A fixed step up to 3 inches deep at the front of an existing automobile transporter until April 29, 2005. It will be the responsibility of the operator of the unit to prove that the step existed prior to April 29, 2002. Such proof can be in the form of a work order for equipment modification, a receipt for purchase and installation of the piece, or any similar type of documentation. However, after April 29, 2005, the step shall no longer be excluded from a vehicle's length.​
    (c) Each exclusion allowance is specific and may not be combined with other excluded devices.
    (d) Measurements are to be made from a point on one side or end of a commercial motor vehicle to the same point on the opposite side or end of the vehicle.
    [67 FR 15110, Mar. 29, 2002]
    http://www.gpo.gov/fdsys/pkg/CFR-2011-title23-vol1/xml/CFR-2011-title23-vol1-sec658-16.xml
    Link to Appendix D: http://www.gpo.gov/fdsys/pkg/CFR-2011-title23-vol1/xml/CFR-2011-title23-vol1-part658-appD.xml
    OneCosmicGuy Thanks this.
