How much are coils worth?
Discussion in 'Flatbed Trucking Forum' started by Ann Eiffel, Mar 19, 2014.
  1. Ann Eiffel
    Ann Eiffel Light Load Member
    89
    58
    Nov 13, 2013
    Was on the Ohio Turnpike heading east and noticed a coil in the ditch at MM 44. It was obviously there due to a mishap this winter and recently surfaced with the melting snow. Is it not worth salvaging or what?
  3. Triad
    Triad Light Load Member
    242
    286
    Apr 15, 2011
    Columbus, OH
    They're pretty cheap, as products hauled by truck go. Some of them aren't even worth $5000. Some companies even pay more to ship the stupid thing than it's actually worth. Not that it isn't worth it to pull one out (some of them can be really expensive if they're a finished metal or something), just that it sometimes isn't possible. There isn't much equipment that can pull a 50,000 pound coil out of a ditch that easily. A lot of times, they just let 'em rot. I think there's still one in the dirt near a ramp in Akron, OH where I saw the whole thing closed down so they could pull the truck out three years ago. They're just heavy and hard to get out and the cost of a crane that could do it is probably way more than it's worth.
  4. nikmirbre
    nikmirbre Road Train Member
    5,371
    9,543
    Jul 27, 2011
    High Point NC
    There is a huge paper roll on I77 s in VA near mm 3 or 4 in the middle, you have to look hard to see it!! just fyi…….
  5. milskired
    milskired Road Train Member
    3,829
    1,401
    Jul 20, 2007
    Plainfield, IL
    That thing would be easy to lift out of the ditch with a rotator rig. The one O'Hare towing in Chicago towed my broke down dump back in November and that guy said the rotator he operates is setup for 60 tons. That coil is probably just trashed and was covered in snow so they decided to wait for the thaw. It will be gone here soon.
    Lone Ranger 13 Thanks this.
  6. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Scrap steel is way up. Almost $400/metric ton
    "Hang - Man" and milskired Thank this.
  7. ReeferOhio
    ReeferOhio Medium Load Member
    596
    557
    Nov 29, 2010
    I've always wondered this as well, what does a 45K coil cost?
  8. "Hang - Man"
    "Hang - Man" Heavy Load Member
    737
    583
    Nov 12, 2013
    Western PA
    Just called about automobile scrap yesterday, $11.25 per hundred -- 50,000lb coil =$5625.00 worth of scrap.
  9. cpape
    cpape Desk Jockey
    2,151
    2,263
    Jul 15, 2010
    Dubuque, IA
    New, coming out of the mill with certs, a plate coil would probably be around $50K. Automotive grade sheet metal would probably be $100K.
  10. Macneil
    Macneil Heavy Load Member
    711
    426
    Dec 15, 2010
    Sudbury, ON., Canada
    Most rotator tow trucks would be able to get that out as someone mentioned above..One we had where I used to work was just a little guy and it was a 40 ton. Could pick up rigs and trailers like nothing..
