I'm curious to know how long a set of steel or aluminum rims will last before they need replacing. I talked to the owner of an LTL carrier and he mentioned some stats for his business (he also described the process/schedule for refinishing wheels and other maintenance). Talking to another fleet manager and a wheel/tire sales rep, they both mentioned that, outside of an accident or other obvious damage, that eventually they need to be replaced. Does anyone care to comment on the lifespan of wheels for Class 8 tractors and trailers?
How many years can an aluminum or steel rim last?
Discussion in 'Questions To Truckers From The General Public' started by trucking_noob, May 24, 2013.
16 years and still going strong on my truck . all aluminum
10 years and 1.1 million miles on mine . They look great. I remember in the 1990's there were some defective aluminum wheels that would crack. I think they cracked at the holes for the studs.
So a wheel salesman thinks you ought to replace wheels occasionally. mmmmm.. very interesting. I think car salesmen think you need a new car.
Never heard of replacing wheels other than when they are damaged or defective. -
Actually, the OP has good right to ask this question.
General rule is 10Y for alloy's and 15 to 20Y for steel.
But as with all this mechanical it depends on the maintenance.
Steel has rust issues that in time will not allow the tire to seal on the rim.
Sandblasting is a solution but i know trucking firms that when they add up the cost off sandblasting and painting just scrap their old rims and prefer to buy new ones.(steel rims are very cheap to buy)
I will add that in my opinion giving new steel rims an extra paintcoant before you put then in service will extend their life.
Alloy rims,Alcoa's,can wear on the 2 outer edges.
Sand and dirt gets between the rimedge and the tire which over the years sharpens the outer edge.
If left unthreated the edge becomes so sharp that it damages the tire.
The fix is very easy.
Use an angle grinder to smooth out the edge and just use a caliber to check that there is enough edge left to safely mount the tire.(this info came staight from Alcoa) -
Assuming the steel remains sound (no rust) it'll last forever provided you never exceed 50% of its yeild strength. Aluminum will eventually fatigue and fail. How long it lasts depends on how much stress you put it through. For example, at 50% of yeild strength, aluminum will last 500,000 cycles. At 30% of yeild strength it'll last 10,000,000,000 cycles. For a semi wheel turning 500 revs/mile, a wheel at 30% stress would last 2,000,000 miles. And I suspect wheels aren't even stressed that much (not to mention 6061 aluminum alloy has more fatigue resistance than pure aluminum). The problem is you occassionally stress wheels much more (hit potholes) so their life is just hard to predict.
I wouldn't have a problem running aluminum wheels until they crack -- you just need to be periodically inspecting for cracks so you can retire the wheel while the cracks are still small. -
I live for posts like this. I have seen everything from Budd wheels, to Dura last. Depends on how you treat them. Hit curbs, your going to have problems. Get Em' hot, your going to have problems. There the only thing between you and walking. I use Alcoa rims about 8 years. Trailers are the shippers problem.
Right, daf105paccar. Your statement about being unable to hold a seal does ring a bell now. So generally, a wheel treated right should last indefinitely but may be subject to failure if the bead gets damaged (or if there is an obvious accident like striking a curb too hard).
