How many Straps, Chains,Binders?
Discussion in 'Flatbed Trucking Forum' started by Vegas_Driver, Apr 10, 2012.
  1. Vegas_Driver
    Vegas_Driver Bobtail Member
    5
    Las Vegas, NV
    Could someone tell me how many of each you carry? Thanks...
  3. The Bird
    The Bird Medium Load Member
    386
    268
    Apr 10, 2012
    White Rock, NM
    Obviously as many as you have winches... :)
    I carry 18 straps (+ my short tarp strap) and 10 chains/binders.
  4. glowstickz
    glowstickz Light Load Member
    112
    55
    Aug 24, 2010
    Duncan Falls, OH
    16 3/8 chains and snap binders 20 4" straps
  5. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    I carry ten 4 inch straps, four 2 inch ratchet straps, ten chains. ten snap over binders, and two ratchet binders.
    I want to put two more winches on my trailer so I could have a total of twelve 4 inch straps.
  6. Phil1Fla
    Phil1Fla Light Load Member
    298
    53
    May 12, 2008
    Beavercreek, Oregon
    Well it depends on what you are hauling on your trailer. I use to have 2 30' & 18 20' 3/8 chains, and a pile of short chains, I had 1 binder per chain plus 5 ratchet binders. 30 2" ratchet straps, 6 3" ratchet straps and 12 4" straps mounted on the trailer. and I would have try and find a couple more straps or chains to make it home. But the whole thing I worked for a construction company and loaded in layers. I tied down each layer before I built the next layer. it was always nice to have a few extras (chains or straps) just because you never knew what they would add on the way home. in normal running you will need a lot less unless you are hauling just about anything that comes along. Then you will need larger chains. I had a couple 20' 1/2" chains to boot. I pulled a stepdeck and hauled a little of everything. from normal sized to oversized.
    Rollr4872 Thanks this.
  7. Allow Me.
    10,718
    12,404
    May 28, 2009
    Rancho Mirage, Ca.
    12 chains/binders and 16-18 4" straps.
  8. Logan76
    Logan76 Crusty In Training
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    12 4 inch straps, 10 chains/ binders, 2 lumber tarps, 2 4 foot drops, 2 smoke tarps and a whole crap load of tarp straps/ bungies.
    That's what seems to come on most of our trailers (we swap trailers).
    I carry in my truck, four 2 inch hand straps, a bunch of felt edge protection/ plastic corners a bunch of assorted lengths of bungies and lots of tools.
    We have all Manac and Reitenour 48/53 x 102 aluminum's.
    freight vary's but seems to be mostly lumber/super sacks from what I've seen so far.
  9. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    For what trailer?
    What kind of freight?
    My 4" straps collect more mildew than use, along with the portable winches.
    2" straps are used very occasionally for blocking etc.
    7400lb rated chains and binders get used daily though.
    Forgot how many straps etc, but I have 14 chains/ratchet binders, along with 8 shorty chains. For pretty much everything I haul, I have 5 full length chains, 12 binders, and my shorty's stored in my trailer box. Rarely I have to grab another length of chain as I can normally get 2 binders on 1 length of chain.
    I haul machinery 99% of the time on an RGN though. If you pull a flat hauling lumber, it will obviously be a lot different.
    Too vague a question IMHO.
    Martin
  10. TDriver4Life
    TDriver4Life Medium Load Member
    Hey Logan- keep us informed on how/what you are doing with FTI if you can. I have been interested in them but the feeling does not seem to be mutual.
  11. Logan76
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    So far it's been great, I'm sure I wont make the same kind of money I would if I were willing to stay out more (I told them I wanted mostly local work) but they do tarp almost every load and it's alot of work, I could see why some of the older guys don't like to do the flatbed here.
    Their customer work seems to be mostly Trim board and super sacks and the trim board usually just needs a smoke tarp unless it's going somewhere that requests a full tarp, and the sacks get fully tarped.
