How many gallons of DEF does a typical tank hold?
Discussion in 'Questions From New Drivers' started by TawcoTruck, Jul 19, 2023.
  1. TawcoTruck
    TawcoTruck Light Load Member
    155
    224
    Dec 11, 2022
    I've been getting low Def de-rate errors and codes that come and go. Now I'm starting to think the dash gauge might be faulty. I don't get def everytime I fill up.
    The guage was sitting at 75% full. The truck went into de-rate. I thought about it and I hadn't gotten def in awhile. I pulled over to add def to see if it did anything and the tank took 7 gallons. I sat for awhile at idle and the codes and de-rate went away.
  3. Espressolane
    16,974
    102,288
    most road trucks are 16 to 21 gallons. Depending on manufacturer and model.
    It may not be low. It may be the QLS is going bad. Could also be a plugged filter, weak pump or the dosing injector any number of things. It should set a code for the problem. Will need to connect to it with a computer to read them.
  4. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    813
    1,584
    Dec 15, 2021
    They did 3 regens at our shop on my truck,hooked up to the computer.It tested everything in the system and the codes cleared and didn't come back.
    Forced regen.
  5. Opus
    114,726
    The most I ever did was about 10
    TawcoTruck Thanks this.
  6. tscottme
    tscottme Road Train Member
    I think my last truck had a 12 gallon DEF tank. I don't recall. I routinely only filled it every 3rd fueling. I routinely only toped-off the DEF when it got down to 1/4 full.
  7. Concorde
    Concorde Road Train Member
    4,345
    15,427
    Jun 29, 2016
    West Melbourne Florida
    Mine holds about 30 gallons..
    Your problem could simply be a plugged vent. All you have to do is remove the cap after running the truck awhile..if you hear a vacuum sound when taking off the cap, your vent is clogged.
    tscottme, TawcoTruck and RockinChair Thank this.
  8. TawcoTruck
    155
    224
    Dec 11, 2022
    Unless I'm mistaken I don't think I can force a Regen on this truck. It's a 2020 International.
  9. North Pole Nightmare
    813
    1,584
    Dec 15, 2021
    Mines a 2019 Freightliner, DD 13.
    It has to be connected to a computer to do it.It took about 3 hours to run it 3 times before everything cleared up.
    It gets very hot when they do it.
  10. North Pole Nightmare
    813
    1,584
    Dec 15, 2021
    It cleared all the codes and runs great now.
  11. Iceman1643
    Iceman1643 Light Load Member
    82
    115
    Dec 29, 2023
    Bmore MD
    My 2022 Cascadia holds 20 gallons.
    But our DEF systems all need trashed! There's just as many downsides as upsides (probably more down) I'd take that entire system off in a heartbeat if I could.
    jeff18 and cuzzin it Thank this.
