I feel like a complete idiot because I know the pre-trip but when I was under the gun I fell apart and forgot to mention exactly what I would check for on a number of items, and I ended up not getting enough correct to pass.
I failed to mention that the slack adjustor is not cracked, bent, or broken and has no missing hardware, and since I began on the front right side, I missed it on all the subsequent wheels because we're allowed to say "I'd check this axle the same as I would my front axle, checking my frame, brakes, suspension, tires, and wheels," or "I'd check this side the same way as I would my other side," etc., therefore I missed it for all the other axles. I failed to mention that my brake lines aren't cracked, bubbled, or blistered and not leaking. I failed to point out damage to the trailer bulkhead and a dent in the catwalk. I failed to point out the bent landing gear crossmembers. I was even docked for failing to mention the non-existent mud flaps on the tractor- they had been removed by the school because they interfered w/ the trailer landing gear. There were a few more things but y'all get the idea. But I've been reviewing everything lately and I know what it is I need to remember.
I did fine on the air brake test and in-cab inspection though.
Now I have to wait to see if they can get me in for a re-test, on a standby basis, because the scheduled tests are booked weeks in advance.
I know when it comes to the yard skills and road test, I'll do fine. But the school did tell me that I'll get a day or two of advance notice of when I can get in on standby and will be able to get a few hrs. of practice in the night before so I'm fresh and ready.
So how many others fail their pre-trips? Does it happen very much?
How many fail their pre-trip on the CDL test?
Discussion in 'Questions From New Drivers' started by Tak, Jan 13, 2014.
Page 1 of 5
When i went to do my pre-trip for a class B....I TOTALLY MESSED IT THE HECK UP!!! Went back a week later and nailed it! More people probably miss it first time than you could imagine. You WILL get it next time!
What's a pretrip
bottomdumpin, nb629 and G.Anthony Thank this. -
Yep, when I regained my CDL last year I failed the pretrip and then went back and passed it but then failed the skills test (in the middle of a dust storm). Keep the faith... but it sucks being on standby.
PyleIt Thanks this. -
Before you take the pretrip part of the test tell your examiner "I will be checking all of the items I will point out for cracks, leaks, breaks, signs of excessive wear, damage, correct levels or pressure, or any other possible sign of something being unsafe or missing." Then all you have to do is point and touch. You do not have to name the parts. A pretrip is a visual thing.
Just passing by, Acidicanthrax and Tak Thank this. -
Depends a lot on the tester. It's OK to ask the tester what exactly he wants, as in clutching or floating the gears. Don't assume you have to double clutch, he may say it's ok to float. You won't know unless you ask. Ask him if he wants you to explain EVERYTHING as you do the pre-trip, or can you say the same for the other side. Some will even tell you to skip the rest of this side. Just don't rush yourself, there is no time limit.
UturnGirl Thanks this.
I failed the road test by touching a curb but did fine on the rest. For the pre trip simply walk around and point at everything you see. start with driver steps, window, miror door, rim tire, axle, hub seals, brakes (pad, slack adjuster, hose etc.) steering, etc...we haven't event moved from right outside the door yet and i got all that. Just look at the truck and mention everything you see. You cant over pretrip a truck lol. You have the cheat sheet right in front of you lol.
Page 1 of 5
