How long will Reefer fuel last
Discussion in 'Questions From New Drivers' started by Kolorado, Apr 10, 2015.
  1. Kolorado
    Kolorado Medium Load Member
    481
    648
    Feb 28, 2015
    Colorado/Texas
    At - 10
    And at +20
    Thanks for any reply
  3. joesmoothdog
    joesmoothdog Heavy Load Member
    737
    1,144
    Aug 5, 2013
    OTR
    Cycle?Continuous?TK?Carrier?Region?Trailer?Tank size?
    Varies. But a few days.
  4. GenericUserName
    GenericUserName Road Train Member
    1,543
    13,065
    May 17, 2014
    Santa Monica, CA
    It depends entirely on the reefer unit itself. In my experience the age of the unit is the biggest factor. I have had older units barely last me a day and brand new ones up to 3 1/2 days. Generally around 2 days or so. But always check the gauge while fueling your tractor to be safe.
  5. ncmickey
    ncmickey Road Train Member
    3,820
    7,104
    Jun 21, 2013
    Durham NC
    The reefers we have use between 1/4 and 1/2 tank a day depending on age, setting, outside temp ect...I just fill mine everytime I fuel the tractor. Same with DEF... everytime. If I pick up a trailer, I fill it the next time I fuel. Even if I'm not on a refrigerated load. I'll need it next load or the next driver will.
    MilkyJay Thanks this.
  6. SHOJim
    SHOJim Road Train Member
    3,399
    17,208
    Apr 19, 2011
    Columbus, Ohio
    Until il it runs out? 😎
    2Girls_1Truck Thanks this.
  7. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    No matter how long it last its wise to always check your reefer tank and if you ever drop it at say a pacing house terminal or wherever loaded,always make sure the tank is full especially at a customer because they will refuse the load till you go fill it.
  8. TLeaHeart
    TLeaHeart Road Train Member
    4,169
    2,614
    Apr 1, 2008
    casper, wy
    all depends on the refer tank size... some are 25 gallon, some are 50, some are 75, some are 100.... best to fill it everytime you fill the ruck.
  9. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    Not sure if the numbers you gave were different temp settings or refr temp and outside air temp.
    Outside ambient temp is also a factor.
    Mikeeee
  10. bad-luck
    bad-luck Road Train Member
    3,245
    5,944
    Nov 16, 2013
    Baltimore, Maryland
    you actually scare me with these type of questions..... kind of like asking how long a tank tank of gas will last in your car?
    GenericUserName Thanks this.
  11. GenericUserName
    1,543
    13,065
    May 17, 2014
    Santa Monica, CA
    Its just an unnecessary question. If you just monitor the fuel gauge you will have your answer within the next couple of days....
