How long will an at fault accident appear on my DAC?
Discussion in 'Questions From New Drivers' started by Rosa Lilly, Apr 25, 2019.
  1. Rosa Lilly
    Rosa Lilly Bobtail Member
    I was doing a 45 45 into a parking space at a truck stop during training. My trainer was my ground guide. I was expressing to him that I couldn’t see the truck beside me. He continued to guide me in the direction. The tail end of the trainer made contact with the front end of the tractor beside it. How long will an preventative accident be on my DAC report. It’s not on my MCR
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Sounds like your trainer is an idiot.
  4. Oor
    Oor Road Train Member
    1,374
    3,538
    Jan 11, 2012
    Won't go on your dac till you quit, if then. Depends if the trainer or company stuck it on you. Ask.
    Document the date and details anyway, just in case, and note it was in training. Shouldn't be much of an issue for hiring at a different company, unless you try to hide it.
    Btw, learn anything? Like goal?
    COBB2070 and Chinatown Thank this.
  5. Chinatown
    Chinatown Road Train Member
    73,230
    164,412
    Aug 28, 2011
    Henderson, NV & Orient
    Are you attending a trucking company cdl school?
    x1Heavy Thanks this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    That's not good, you apparently knew of a big rig on your right. Even if you suspected it. Why did you move right? YOU are the final captain of the ship as it were the trainer can only give suggestions. Now... if this is a school then the trainer screwed up very badly and it should be looked at carefully.
    However if you are talking about DAC already, you probably are with a company. That would be failure to stay in lane charge to the state via citation and the damages will belong to your company to pay. It's going to be your fault.
    Ive broken say a curbing which was worth a thousand dollars in Sayre once, that took three years to stop telling and retelling that story to future employers who pretty much laughed, particularly the later ones when they saw just how tight it was for a spread axle.
    UsualSuspect Thanks this.
  7. Moose1958
    Moose1958 Road Train Member
    15,088
    33,170
    Dec 17, 2010
    Williesburg, Virignia
    Everybody has got to stop worrying about DAC. DAC is only a service that helps a carrier stay in compliance wirh 391. Even if DAC dropped the accident the carrier has a record that is part of your PERMANENT file. YOU the driver have got to fill out an application and honestly answer those questions. If they ask for 3 years back and the accident was 4 your good.
  8. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    it'll stay on your employment record, with THAT company for life, or until they go out of business.
    It'll stay on your DAC (when you quit) for 7 years, then DAC can no longer give out that information by law.
    anytime you fill out a job application, make sure you mark that down, as it IS A COMPANY black mark, not a DMV black mark, which DMV records can be for 3 or 5 years.
    as long as your employer is in business, they will most certainly inform any new employer
    in also other news, many employers MAY NOT even cooperate with a new employer, asking for a reference. they may only decide to give your start date and end date, and your job duties.
    in the end...GET OUT AND LOOK.....(GOAL), take NO ONE'S WORD.....
  9. WesternPlains
    6,274
    51,393
    Sep 1, 2017
    Till the cows come home.
  10. supertrucker79
    supertrucker79 Light Load Member
    135
    251
    Feb 4, 2019
    Pittsburgh, PA
  11. buddyd157
    13,506
    34,549
    May 25, 2017
    under a shade tree
