How long should a coolant flush take on semi truck?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by cynthia_afs, Mar 31, 2021.
  1. cynthia_afs
    cynthia_afs Bobtail Member
    We have Motor's T&L guide and I can't find the time in there for radiator or coolant flush. The customer says 2 hours is too high so trying to get some input to compare.
  3. AModelCat
    154,214
    Takes what it takes. If the system is full of oil or fuel it can take several flushes to get it clean.
  4. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    For maintenance I would agree with 2hrs plus .5 if it has a filter.
    Contamination with oil or fuel is totally different story as stated above and sometimes it takes 10 hrs or more to get it done right.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,417
    6,430
    Aug 26, 2014
    And how are you flushing it? In Florida you would need to be in a facility with a recycle waste water loop.
    I do not have that problem but try to be nice to the earth. Normally do the regular Cascade, Dawn, Simple Green, Greased Lighting type thing. Run them and drain it out. That can easily be two hours.
    Started doing that and hooking a hot water pressure washer up to the block. After the engine has ran a half hour or better open the drain on the radiator and take the radiator cap off. Fire up the pressure washer and run it until the soap suds stop. Then a bit longer and drain it all out.
    When transmission coolers fail I have never found anything that really gets all the stuff out. 6 hours on one.
    Two hours is reasonable in my opinion.
    clausland, spsauerland, Heavyd and 4 others Thank this.
  6. p608
    p608 Road Train Member
    2,181
    2,991
    Nov 10, 2016
    You would have to define flush, if you mean drain it and run a hose in it until it runs clear 2 hrs may be high, but if you mean drain it, and run cleaner through it, than it's about right, depending on what you run into.
  7. Evil_E
    Evil_E Heavy Load Member
    790
    537
    Nov 25, 2011
    Dexter,MI
    Ok, so here's my question:
    These new cooling systems are extended life coolant (OAT) or (NOAT) mixed with clean, distilled water. Regular coolant testing/analysis is the only true way to keep up on the maintenance of such a fluid.
    Then, the system is flushed with tap water plus some other magical cleaner....adding contaminants throughout the system. Drained and refilled with (hopefully) the correct coolant.
    How does that NOT leave contaminants in the system? It's like draining the engine oil, filling it up with water to "clean" it, draining the water and refilling with oil :confused:o_O
    Ffx95 Thanks this.
  8. Lowboy456
    Lowboy456 Light Load Member
    278
    127
    Mar 14, 2017
    I think ot depends on the system. I flushed a system 7 times once. That coolant looked like mud to start with. Last two times was without Dawn.
  9. believe456
    believe456 Light Load Member
    191
    22
    Apr 22, 2015
    I have a Cummins that is muddy after oil cooler went out. How much dawn should i use compared to water
  10. God prefers Diesels
    4,198
    22,258
    Jun 26, 2020
    South Texas
    When mine went out, I flushed 12 hours a day for three days straight. I bought a bottle of Cascade about the size of a gallon oil jug. I'd say it was about half a gallon. I flushed with a third of it three times in a row to use the whole jug. Then I flushed four or five times with Dawn. Basically I just gave it a good strong squirt each time. Then I flushed with hose water. Still oily. So I flushed a couple more times with Dawn. Good healthy squirt each time. Basically a stream of Dawn for about three seconds. Then I flushed with hose water again, and it was a lot better. After that, I bought two bottles of actual Superflush, and flushed twice in a row with that. Then I flushed with hose water again. After that, I flushed out the hose water with twelve gallons of distilled water. I drained the distilled, and filled with six gallons distilled water, and six gallons of concentrated antifreeze.
    Anyways, don't be scared to put too much soap into it. It's going to take a lot. And each time I flushed, I ran the engine at 1,200rpm for two hours. It took forever.
  11. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    It takes longer to flush one out with oil/fuel in it than it takes to do the job to fix the problem usually. Way longer. But you really are not "working" on it for that time. Fill, run, drain. repeat. So 2-3 hours of actual work is probably about the right amount to charge unless it is really really bad.
