We were bobtail today and I noticed the front axle was hopping a bit which it never does when we have a trailer and our truck almost has 150,000 miles on it. Nothing is leaking out of the shocks but I’m wondering if it is time to change them and if so should I replace them with Volvo shocks or something else? Is it easy to change them yourself?
How long do OEM shocks last?
Discussion in 'Ask An Owner Operator' started by Midnightrider909, Jun 4, 2019.
After driving for a couple hours after starting your day, pull over and put your hand on each one. If the shock is warm it’s working, if it’s “cold” then it’s not.
The Gabriel gas shocks seem to be affordable and good. I’d say most shocks go out by around 300,000 but with today’s roads...
Changing them is very easy, it’s mostly about having wrenches or sockets large enough. The shock bares no weight so no need to jack the truck up.HopeOverMope, PE_T and Midnightrider909 Thank this. -
I have shocks replaced at 200k
I actually thin you're supposed to do them at like 75K miles. No one does, but I'm pretty sure that's when they are supposed to be done. Might even be 50K.
@Bakerman
They don't cost much. Wrench zips them on / off in like 15 minutes.
I think he put Monroe's on mine. They're yellow.Bakerman Thanks this. -
Midnightrider909 Thanks this.
If you drive across I-70 in Indiana, your new shocks will last 5 miles. 10 tops.
Iceman1643, JoeyJunk, shatteredsquare and 6 others Thank this. -
Dave_in_AZ Thanks this.
tommymonza and Dave_in_AZ Thank this.
