How long can you drive when regen light is flashing
Discussion in 'Freightliner Forum' started by Timj29, Jan 10, 2023.
  1. Timj29
    Timj29 Bobtail Member
    10
    8
    Dec 16, 2021
    I drive a 2013 Cascadia. My regen light came on while dropping a trailer, but I was going right back to the interstate. I figured that would fix it, but I got stuck in a little bit of traffic, and then the light started flashing.
    Do you need to pull over right away and do a park regen, or can you drive on the interstate for a couple of hours?
  3. Judge
    89,658
    The more you drive the worse it’ll spot up/longer it’ll take.
    Flashing i’d say 45-1.5 hours then red light and you’ll be creep mode/limp home 5mph.
    gentleroger Thanks this.
  4. ducnut
    ducnut Road Train Member
    2,587
    7,805
    Dec 31, 2010
    SPI
    Pull down your sun visor. The regen directions are there.
    Flat Earth Trucker, Numb and Siinman Thank this.
  5. Lennythedriver
    Lennythedriver Road Train Member
    2,346
    7,934
    Feb 14, 2020
    If the A-1 box is out, it won’t go into regen and your screwed, it will derate. Each time you shut the ignition off and turn it back on progresses it more rapidly to a derate. I’m my Experience once you get the second warning on the dash usually the red dot, you’ve got about 100 miles. And the last 50 of those 100 miles will be at 55 mph no faster. Sometimes you can get a little more. Face reality and deal with it my friend. Or you’ll be paying for a $2000 tow job on the side of the freeway.
    nredfor88 Thanks this.
  6. Flat Earth Trucker
    4,237
    16,018
    Nov 19, 2018
    It's only taken 25 minutes maximum for any tractor I have drove to complete a regen. Place your triangles if you have to pull over onto the shoulder.
  7. Todd727
    Todd727 Medium Load Member
    300
    583
    Jun 7, 2021
    It should be regenning during normal drive, so if it isn't, there are probably bigger issues that a manual regen isn't going to fix. Are there any codes? I know if the EGR fails, it will soot up and it can't/won't regen.
