How heavy is this 379 w/o engine?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Heritage1lw, Oct 31, 2024.
  1. Heritage1lw
    Heritage1lw Bobtail Member
    35
    162
    Oct 18, 2024
    Newfoundland
    I’m trying to make arrangements to pick up this truck for reasons yet undetermined.
    It’s an 04 379, single frame highway spec, no steer axle/springs, no engine or transmission. It still has the rear drive axles so I’m going to pick up the front of it and drag it around to load/unload it. My question is can anyone give me an approximate guess on how much weight I’m going to be lifting on the front of the frame. A buddy thinks his warehouse forklift will pick it up and move it as long as it’s on decent ground, but I’m hardly convinced a forklift will do it, in saying that I’m not too experienced in the forklift category
    Sons Hero, cke and Flat Earth Trucker Thank this.
  3. Big Road Skateboard
    5,687
    29,604
    May 2, 2021
    I'd figure right at 11-12k as it sits
    cke, Flat Earth Trucker and Oxbow Thank this.
  4. Heritage1lw
    35
    162
    Oct 18, 2024
    Newfoundland
    Thanks, figure 3-4K on the front end maybe?
    cke, beastr123, Oxbow and 1 other person Thank this.
  5. Heritage1lw
    35
    162
    Oct 18, 2024
    Newfoundland
    I don’t know what they tare on the steer, I ran a 389 for a couple years but never scaled empty. If anyone could tell me roughly the empty weight on the steer for a 379 I’d get a rough idea. C15 was 3300lb, so call it 4K for engine and trans, probably 1k for steer axle sound approximate? Wheel to wheel with leafs and all?
  6. Big Road Skateboard
    5,687
    29,604
    May 2, 2021
    Axle, wheels, engine, trans, driveshaft, hood, accy's.
    Probably total 6-7k
  7. Concorde
    Concorde Road Train Member
    4,345
    15,427
    Jun 29, 2016
    West Melbourne Florida
    My 389 is right around 18k / 20k wet.
    Empty on the steer 11k..285 wheel base.
    I got a scale ticket in the truck if you need a precise number. Unfortunately I’m at home and away from it. Will be going to it later today to grab some gear.
    A little reverse math..
    @ 80,000
    - 13, 200 is what my trailer weighs..fact
    - 45, 800 is absolute maximum I can haul.
    Balance 21k wet full gear
  8. W923
    W923 Road Train Member
    1,296
    3,924
    Feb 28, 2022
    A regular warehouse forklift with approximately 5k capacity will probably lift it but if you go to backup it will nose dive if it pulls hard at all and I highly doubt it’ll get it on a trailer unless it’s a paver style lowboy or traveling axe trailer. For reference and it’s not a very good one a farm loader tractor that will barely lift a 3500 pound super sack won’t lift the front of a similarly speced ford l9000 in similar condition
  9. 062
    062 Road Train Member
    6,143
    33,156
    Oct 20, 2013
    Traction and ground clearance are going to be your two biggest problems.
    RocketScott and Deere hunter Thank this.
  10. Ridgeline
    22,103
    113,210
    You need a 15k capacity off-road forklift to move that onto a trailer and to get it off.
    I know, trust me I went through this just last May.
    Oxbow Thanks this.
