How hard is it to replace a steering wheel with the smart wheel?
Discussion in 'Kenworth Forum' started by Cobrawastaken, Mar 17, 2021.
  1. Cobrawastaken
    Cobrawastaken Medium Load Member
    450
    856
    Apr 20, 2018
    Tulsa, OK
    I'm looking at buying a used T680 and it doesn't have the smart wheel (buttons for radio controls and cruise control on the steering wheel). Is it possible and if so is it even worth the effort to try and replace the standard steering wheel with a smart wheel?
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    I would just ask Kenworth what is involved just to get an idea if it's worth it or not.
    Magoo1968 Thanks this.
  4. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    You need clock spring , smart module , new wiring to steering column , wheel.
    I plan to do on my t660
    QUALITYTRUCK Thanks this.
  5. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    There are aftermarket radios that have a wireless remote that installs on steering wheel.
  6. skallagrime
    skallagrime Road Train Member
    3,836
    9,880
    Apr 10, 2012
    Indiana
    Why in the name of sanity do you want a less comfortable, more dirt prone overpriced peice of junk that will deteriorate rapidly and cause more problems as buttons fail (few years ago the smartwheel direct replacement was about 2.5k) instead of a standard tilt/telescope wheel?
  7. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    tarmadilo and Isafarmboy Thank this.
  8. Cobrawastaken
    450
    856
    Apr 20, 2018
    Tulsa, OK
    That was a good idea. I called a KW shop and the wiring for the smart wheel isn't built in if you don't get it from the factory so they'd have to do a lot of rewiring. It's also possible that the ecu would have to be programmed to recognize the buttons. Yeah I can live without the buttons.
  9. 2020w900l
    2020w900l Bobtail Member
    Can I remove my smart wheel and replace it with a aftermarket wheel without buttons and still have all the functions?
  10. skallagrime
    3,836
    9,880
    Apr 10, 2012
    Indiana
    You will need to set up new switches and figure out which wire goes where on the new switches. But yes.
    Consider attached picture, cruise control set/speed up and resume/slow down is simply a momentary switch, on off is simply a regular switch
    Bottom left, winch in is speed up/set cruise
    Winch out is decel/resume.
    Next over is simple on off
    Dont do it if you dont like a challenge but its relatively simple
