How hard and strict are truck driving schools?
Discussion in 'Trucking Schools and CDL Training Forum' started by madinjeck, Dec 2, 2010.
  1. madinjeck
    madinjeck Bobtail Member
    Thinking of going to truck driving school and I was wordering how hard is it to drive a semi plus dealing with the loads,different roads,etc.? I can't drive manual trans to good is those double set of gears and multi sppeds hard to figure? Anyone who is attending a school or went through one and is driving now would be a big help. Thanx.
  3. Mike'
    Mike' Medium Load Member
    479
    145
    Nov 22, 2010
    Toledo, Ohio
    You won't pull a trailer while loaded in school most cases. Also, learning the narrow and difficult roads are the ones you want to learn while you have an instructor next to you. Learning to shift is something that EVERYBODY has to do. I know some veterans that get into newer trucks and are told not to float gears and they have trouble. You will learn. It isnt as daunting as it appears.
    Go for it! I am. :D
  4. chainbreaker
    chainbreaker Light Load Member
    55
    24
    Nov 12, 2010
    Burnside, Ky
    everyone is different when it comes to learning anything, driving is no different. You have to develop good hand, foot and eye coordination. That can be practised and done with effort. Shifting gears is all about coordination. People who have never been around a truck usually pick thispart of fairly easily, but I have seen some that just made me shake my head. No matter how hard I tried they couldn'tpick it up. Then I would just walk away and let them practise on their own and bam, thye figured it out. If you go to school you should get plenty of time in the truck and it will get you use to the sixe and the like. Be the first to step up and volunteer to get behind the wheel, thats the only way you learn is behind the wheel.
    As far as the job goes, its tough, its real tough and not for the faint of heart. But like I told all of my students, give the job six months, a good six months, and then you will have a better feel for everything, the truck, the loads, the roads, customers etc.. Now 95% of this job is driving, its fairly easy, but 5% of this job will drive you nuts, pure and simple. Just don't let the 5% outweigh the 95%. This isn't a job, its a lifelong career.
    Hope that helps, and thats my two cents.
  5. 123456
    123456 Road Train Member
    10,555
    5,745
    Oct 22, 2010
    32179
    cjansen37 Thanks this.
  6. Jbrake1960
    Jbrake1960 Light Load Member
    162
    132
    Nov 15, 2010
    Las Vegas
    I dont know if this is standard at other schools, but at the one I just graduated from, I had to take a drug test before starting classes. They want to make sure you will be hireable once you are done.
