How fast does temperature in reefer decrease?
Discussion in 'Ask An Owner Operator' started by SFLTRKBIZ, Nov 24, 2013.
  1. SFLTRKBIZ
    SFLTRKBIZ Light Load Member
    60
    24
    Sep 30, 2012
    I know when you turn off the reefer it gets cold at about 1-2 degrees per hour. How fast does it decrease, with a 55-60 outside temperature.
  3. cuzzin it
    cuzzin it Road Train Member
    3,385
    7,744
    Jan 19, 2008
    Berea, KY
    Depends on unit capacity as to how fast it gets cold
  4. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Also how good the insulation is, what kind of mechanical condition the reefer engine/chiller is in...
  5. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    This too:
    Heat always goes to cold and the larger the differential, the faster the transfer.....a physical property and a reefer removes heat. Doesn't add cold, but removes heat. So what Pony said and this is why.
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Did you run out of fuel? :)
    I'm not sure what you are asking with the reefer off? Are you asking product chill down times? or how long it will hold if you did run out of fuel or break down?
    It depends if the box is frozen it might be 2 degrees an hour versus produce it won't keep very long as it needs air circulation. Most produce continues the ripening process or you might call it decomposing as it evaporates and gives off gases. Most customers have a 2 degree tolerance.
    Being close to room temperature outside the sun will play a role on the box too.
    Then one has to figure the core temperature of a pallet. It's like one big ice cube sitting there and the outside will probe different from the inside.
