How easy is it to damage those little rubber dock bumper things on the end of a truck?
Discussion in 'Questions From New Drivers' started by Gumboslef9384, Jul 26, 2019.
  1. Gumboslef9384
    Gumboslef9384 Light Load Member
    126
    170
    Jul 26, 2019
    TX
    I used to do OTR but recently quit and got a job driving a box truck and delivering to warehouses. The truck is new and I noticed on my post trip that the rubber end on the bumper had been slightly damaged from docking.I know with tractor trailers the padding on the dock usually takes the hit but with a box truck the rear bumper is extended so it hits that rubber thing. How common is it for those to get damaged?
  3. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    It usually depends on how straight you hit it. There I a dock I go to with my box truck that if I don't dump the rear bags it hits high and screws them up because they hit right on the top edge of the dock plate.
    Gumboslef9384 and motocross25 Thank this.
  4. Gumboslef9384
    126
    170
    Jul 26, 2019
    TX
    I usually dont hit it perfectly straight, some docks would be impossible to hit straight because I have to back up to 2 bent concrete poles and lower the ramp onto the truck. Ive never considered dumping the air bags but I dont think it would really help with the docks I go to anyway. The warehouse is ok but delivering to stores is where the really messed up docks are.
    FlaSwampRat Thanks this.
  5. FlaSwampRat
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    Whenever I have ones like that I try to back up until it just barely touched and then move up an inch before running a forklift in it so the up and down motion of the truck doesn't rip them off.
    TripleSix Thanks this.
  6. Numb
    Numb Crusty Curmudgeon
    3,937
    8,743
    Jan 30, 2012
    Charlotte, N.Carolina
    the rubbing up and down ,( suspension give), while loading will knock them off.
    Gumboslef9384 Thanks this.
  7. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    They are a consumable product. 2 bolts and 30 bucks to replace. City trucks take a beating.
  8. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    very common. back up, lightly tap the dock, pull forward about an inch. now you "prevent" those bumpers from rubbing on the dock breaking them off.
  9. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,483
    Nov 11, 2008
    Sorrento Maine
    How common? Frequently, tho a good driver will lessen the damage as buddy has said above
    Matt1924, FlaSwampRat and buddyd157 Thank this.
  10. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    Does not matter he size of your truck or trailer, you should be 1 to 2 inches from the dock, that way as a forklift drives n and out nothing is scraping.
    buddyd157 Thanks this.
  11. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    It also pays to glance at the dock bumpers to make sure one is even there. The very first load I hauled in my new reefer, I backed into an enclosed dock with poor light. Bumped the dock and didn't think much of it until I arrived at the receiver and noticed this when I was opening the doors to unload. Turns out the bumper was missing entirely at the shipper and I bumped a sideways 1/2 inch steel bracket where their dock bumper use to be.
    Matt1924, buddyd157 and FlaSwampRat Thank this.
