How do you takeoff the Bendix AD-IP air dryer filter?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by wr2001, May 1, 2017.
  1. wr2001
    wr2001 Light Load Member
    88
    18
    Apr 27, 2012
    Las Vegas
    I practically got a hernia trying to remove this...how do you take it off? Apparently its a filter that you can change out. I thought you had to replace the whole unit. I've got oil in my air lines and I think its time to replace this. Might be time for a new compressor as well.
  3. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    I think this is the one with a bolt on the bottom of it.
    SAR, wr2001 and Oxbow Thank this.
  4. wr2001
    88
    18
    Apr 27, 2012
    Las Vegas
    Didnt think to check that I'll check it out thanks
    Oxbow Thanks this.
  5. kwswan
    kwswan Road Train Member
    1,900
    9,845
    Jul 26, 2009
    mcminnville,tn.
    It is, I.had one like it.
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Yes, 1 big bolt on the bottom. Do not cheap on a new cartridge, I'd only get genuine Bendix. I've seen a lot of aftermarket replacements come apart on the IP's and put desiccant through the air system. If you ever need to replace it, and AD-SP or Wabco SS1200 is an easy swap and has the easier spin on filters. I've never seen a spin on come apart, even the cheap aftermarket ones.
    wr2001, SAR and Heavyd Thank this.
