How do you slide the 5th wheel on an International?
Discussion in 'Marten' started by 1of1, Apr 25, 2019.
  1. 1of1
    1of1 Bobtail Member
    Apr 25, 2019
    How do i slide 5th wheel on a international
    Upinsmoke Thanks this.
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Same as any other truck ,how about picture's?
  4. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    First thing to know is do you even have a sliding fifth wheel, or is it fixed?
    mjd4277, Upinsmoke and Intothesunset Thank this.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    With an air slide, I drop the trailer. Throw the air slide switch to retract the pins. Then use a pry bar to put it exactly where I want it.
    Least amount of frustration that way.
    25(2)+2, JForce28 and Upinsmoke Thank this.
  6. Mobile Proctologist
    Mobile Proctologist Light Load Member
    98
    40
    Apr 25, 2019
    Drop landing gear..drop air in bags..flip the 5th wheel switch check the clearance between mudflap brackets to the landing gear if your sliding forward don't go more than a third of the front axle and your steer weight is 600 lb per inch of treadwith per tire
    Upinsmoke and miszel Thank this.
  7. Upinsmoke
    Upinsmoke Medium Load Member
    612
    1,206
    Feb 26, 2019
    You'll need to get a gap between your fifth wheel and trailer..any weight on the fifth wheel and you'll have problems.
    Lubricate the pins with soap and water.
    Slowly rock the truck after releasing the pins..should unlock just like the tandem.
    Doesn't take much to move it a few inches.
    uncleal13 Thanks this.
  8. jeastonjr
    jeastonjr Light Load Member
    99
    120
    Nov 4, 2013
    Weymouth,Ma.
    go to a truckstop and ask a old guy.
  9. mjd4277
    mjd4277 Road Train Member
    13,886
    41,483
    Oct 4, 2015
    Fitchburg,MA
    If it’s on a Marten International tractor then none of the fifth wheels on any of the tractor fleet are sliding,they’re all permanently fixed.
