How do you run a truck hard?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Reymann, Mar 14, 2020.
  1. Reymann
    Reymann Bobtail Member
    8
    Feb 21, 2018
    I was advised on this forum to run my Truck hard for a few days. To break in a inframe rebuild and eliminate a engine slobber that is currently going on.
    My normal rpm while going down the road is 1500 rpm in 10th gear. What do I need to do to "Run the truck hard"?
  3. Dave1837
    Dave1837 Road Train Member
    1,396
    4,335
    Nov 16, 2019
    Pennsylvania
    Leave it in 8th gear on the turnpike and set a cinderblock on the throttle for about 30 mins
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    You red line the #### thing.
    Find the worst hills and pull them all day.
    Pound her on bad roads with crumbling pavement and horrible bridges until something breaks.
    alds, mile marker 27 and Coffey Thank this.
  5. AModelCat
    154,260
    You want to maximize the load on the engine. Make it pull hard. Watch your EGT so you don't melt it down.
    bzinger, tj379, PE_T and 3 others Thank this.
  6. McMahons Trucking
    McMahons Trucking Light Load Member
    274
    119
    Jul 4, 2018
    Pull the chicken stick half way. Drive until trailer tires almost ignite. Return stick to normal position.
  7. Reymann
    8
    Feb 21, 2018
    It's my truck I need to run hard.
    I've got some modest 4% 1 mile hills on a local interstate. 10 th gear at 1500 gives me 65 mph, 1700 gives me 70 mph and sounds like its revving quite a bit.
    How about 9th gear at 2200 rpm on the hills.
    To get the " run hard," status.
    Rideandrepair and Coffey Thank this.
  8. Dave_in_AZ
    369,947
    Put 44K in the box, then come out here with me.
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Good article from Steve Scott @IPD on breaking in rebuilt engines.
    PE_T, Rideandrepair, Cat sdp and 4 others Thank this.
  10. AModelCat
    154,260
    RPM doesn't always equal load. It might actually be working the engine less hard by dropping a gear. Honestly, just put a heavy trailer behind the truck and go. JMO.
    86scotty, Tb0n3, tj379 and 8 others Thank this.
  11. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Stay on the go pedal
