How do you open the Hood on a 2013 Cascadia Freightliner?
Discussion in 'Questions From New Drivers' started by zoekatya, Apr 30, 2014.
  1. zoekatya
    zoekatya Medium Load Member
    397
    99
    Mar 15, 2013
    How do you open the Hood on a 2013 Cascadia Freightliner? I released both latches and pulled with all my might. Is there something I'm missing? Maybe a safety latch/Hood release somewhere?
  3. droflex
    droflex Light Load Member
    210
    116
    Jan 30, 2013
    Centralia, WA
    Shine a flashlight in that opening and you'll see how it works.
    Cascadia latches suck.
    I invented new swear words because of those things.
    zoekatya and jeepnut_nh Thank this.
  4. flyingmusician
    flyingmusician Road Train Member
    4,288
    10,905
    Feb 25, 2011
    Jamestown, NC
    Are you sure they released or did the latch handle just pull back? Sometimes the receiver for the latch has to be pulled towards you in order for the latch hook to actually swing free of the receiving bar assembly
    zoekatya Thanks this.
  5. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    At the bottom of each latch , there is a J shaped hook you need to pop out . Once both sides are free should be a one hand pull .
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Pull the end of each latch outwards is all there is to it. Make sure you are sitting on flat ground too because the frame might flex. If it still isn't budging then maybe it needs some adjusting or greasing. Write it up.
  7. CondoCruiser
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    I think I read it wrong, duh! I think he is unlatched he just can't lift it.
    Put both hands on the hood handle and your right foot in the bumper. You might have to use your weight to help with the initial umph! :)
  8. zoekatya
    397
    99
    Mar 15, 2013
    Thanks for all the insightful help!
  9. droflex
    210
    116
    Jan 30, 2013
    Centralia, WA
    No, you read it right. Those hooks on the bottom aren't swing back for him when he pulls the lever. They never worked for me either.
    It's a very bad design. An example of over-engineering.
    CondoCruiser Thanks this.
  10. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    ...and the hoods fit very tight. After you've pulled back the J-hooks, give a little push on the bottom of the hood to loosen it up. No one can pull my hood without first doing that.
  11. ncmickey
    ncmickey Road Train Member
    3,820
    7,106
    Jun 21, 2013
    Durham NC
    I am driving a 2013 Cascadia. The other posts are right...PITA. you pull the latch down, then push it back up a little and get your finger on that J hook on the bottom and make sure it pops off that post in there. After that, push on the hood a little and you'll see it's free...repeat on other side....
    Balakov100 Thanks this.
