How do you know drum brakes are working perfectly?
Discussion in 'Ask An Owner Operator' started by Oldironfan, Feb 2, 2018.
  1. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    Every brake on this truck and trailer are within spec, all have been adjusted and inspected by a mechanic with much experience new front drums and shoes, drives are next. Yet the thing feel like no stopping power ever. Like grease on shoes???? Slamming them empty or loaded not much difference. I keep hearing auto slack adjusters clicking until they stop?
    The compressor is believed to be on its last leg, and takes a bit to long to build up, but does stay at 120psi until hard braking than goes out real quick like after about a few good stabs, also oil vapor is collecting in the primary air tanks. This is the worst truck brakes I've ever experienced.
  3. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    The linings may have glazed over from too much hard use and the heat it generates.
    BoxCarKidd, Hurst, ladr and 1 other person Thank this.
  4. Oldironfan
    5,777
    5,541
    May 22, 2017
    Honestly the best brakes I've ever drove on a tractor, were probably illegal. The drums and pads had a ripple pattern on all drives, lengthwise like a ribbed belt. They were amazing stopping power. And had no fade, I'm sure they were over 3 years old because that's how long I drove it OTR from Wisconsin to the Northwest mostly. But they were about min limits last time I drove it. I've never drove disk brake truck.
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Nothing that gets onto a big truck is "Illegal"
    Oil in the tanks? That tells me that either the tanks are never drained each night (No air dryer?) or the oil etc has compromised the rubber dividing the Spring and the Service air chambers of your brakes.
    I don't know about the rest of it without seeing everything first hand. There is a range of possibilities.
    aussiejosh and Oldironfan Thank this.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    It is winter time here.
    I noticed this in the winter, for me it was just the wrong kind of grease being used in the Slacks and s-cams. Too heavy grease caused a delay in the reaction Time, caused by a slow rotation of the s cam.
    Oldironfan and x1Heavy Thank this.
  7. 201
    201 Road Train Member
    12,044
    24,581
    Apr 16, 2014
    high plains colorado
    A shiny inside of the drum ( can be seen once those guards fall off) says it's working.
    Oldironfan, x1Heavy and Feedman Thank this.
  8. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    Warped drums. There's no way to see it without putting them on a machine to turn them. Which I don't think exists for truck drums.
    I had a truck that took 60 plus pounds and still sucked. Then it got new brakes and drums. Stopped on a dime afterwards. With only 15 pounds.
    I had a 76 Plymouth duster that was the same way. Brake pedal felt like hitting a brick wall. Machined all 4 drums. Worked like a champ.
    Mechanics talk valves and replace but problem never gets fixed. But new drums always does the trick. In every truck I've gotten new drums with.
  9. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Oil is messing up your valves If it's spewing oil into air lines.. IN cold weather they can gum up so bad from oil they freeze and trailer won't air up properly
    Oldironfan, x1Heavy and uncleal13 Thank this.
  10. rollin coal
    rollin coal Road Train Member
    13,080
    25,850
    Mar 29, 2008
    TN
    You can likely eyeball them and clearly see if they are warped that badly. Jack a wheel up. Set something close to the drum, spin and watch the warps.
  11. snowwy
    20,525
    13,261
    Jul 6, 2009
    If you can see that. Your truck is probably falling apart every time you hit the brakes.
    Only way to see it is on a machine. Grinding the surface down till it's perfectly round. Or flat if rotor.
    Drums and rotors warp. That's just normal. Nothing anyone can do. It's caused from uneven heating and cooling. The thinner they get. The worse the warp. And drums and rotors do get thinner from every day use. Just like brakes get thinner.
    Course. Your probably shaking your head and rolling your eyes. But hey. I used to do brake work for a living before changing to steering wheel holder.
    User666, BoxCarKidd, ladr and 2 others Thank this.
