Specifically, how can you decide if windy conditions are so bad that you can't safely run your vehicle?
Is there a number people look for (for example, winds over 40 mph means no go?), or do you go by weather advisory warnings?
As a newbie, I know my temperament, and I know I would think, "I'm not going to let a stiff breeze stop me, I don't want everyone to know I'm a scaredy cat noobie who stops at the first sign of bad weather!" and then proceed to get myself, my rig, and everyone around me, in trouble.
So, what's your advice for windy conditions?
How do you handle high winds?
Discussion in 'Questions From New Drivers' started by Code Red NV, Mar 6, 2016.
Page 1 of 3
As a general rule, the heavier you are loaded, the better off you are. Hauling an empty wagon in high winds is a lot like unfurling a sail. Hauling 40k worth of paper in a dry van will even you out some, but you still need to maintain lane control.
If the roads are icy along with high wind... pull over. You're going to hurt someone. Maybe even yourself.
There is no magic number. It depends on your load. Flatbed, lowboy, livestock trailer, etc. can take higher winds than a dry van. (Unless you're carrying something like big flat sheets of glass or plexiglass, then they turn into a sail, too.) The main thing is how hard do you have to fight to keep it in your lane? Is there a truck advisory out? How is the rest of the weather? Are the roads dry and clear? Is there a dust storm? Has there been a suspicious lack of oncoming trucks?
Worse comes to worse, pull over and take your break. High winds typically blow through pretty quick. Of course, there are states known for them - Wyoming and the like. In that case, run heavy if you can, if you can't give it a trial 10 miles or so. If it's too much of a hassle - or if you're getting swept to the far side of the road after every underpass, it might be time to pull her over and check the weather.T_Bone, pattyj, NavigatorWife and 5 others Thank this. -
Cottonmouth85, taxihacker66, miss elvee and 3 others Thank this.
... or, do this when it's too late to pull over. At least this driver knew to turn into the push; field or not.
@miss elvee is TOTALLY spot-on in her reply.taxihacker66, NavigatorWife, Lepton1 and 1 other person Thank this. -
Frequent mirror checks can give you some room for error. Over!
Dominick253 Thanks this. -
^^^^ true, so can frequent CB checks! Been driving for 30 years + and don't recall seeing this in my mirrors!
bbt_387 Thanks this. -
Depends on u, what type of trailer, weight, and weather.
If u feel unsafe, don't go. There's warning signs in WY if it's high winds they restricted empty trailers or light on the interstate.G13Tomcat and miss elvee Thank this. -
NavigatorWife and G13Tomcat Thank this.
Pimp slap it, how else?
BACON XXL Thanks this.
Page 1 of 3
