Looking at some head work right now.
Not really fun...never done a head gasket on a semi and Volvo (d13) says it's running around 400 lb. so in short...how?
Engine hoist? Where are the mount points.
Thoughts on this? Pricey but I could see it's use in a lot of other areas. Plus it's light for what it is.
Something like this doesn't look tall enough to scraper the head off.
Still...where could I mount lift points? Just screw some disposable bolts into the top of the head and rig up some kind of hook/screw mounts?
Lol one breaks off it's gonna be a bad, bad day.
Good lord why.
How do you guys lift a head
Discussion in 'Ask An Owner Operator' started by cabwrecker, Feb 26, 2017.
Yes I used a engine hoist a few times. For me it was a challenge but it did the job. I was working on a Detroit series 60. I was working on a gravel lot so I put plywood down so it would roll easy. I also removed the front tire and then lowered truck back down. It all from experience from fighting with it the first time.
I lifted mine from the corners holes with bolts & chain. You can do it but do have a helping hand it helps especially putting it back on. I did it by myself be patient and keep everything organized. Be patientcabwrecker Thanks this. -
I've always used either a shop crane or my service truck crane. I have a bunch of CAT bolt on lifting eyes I use.
G13Tomcat, passingthru69 and cabwrecker Thank this. -
Coolant system drops 1psi an hour cold so it's an issue. Checked and double checked for external leaks. Haven't ran bubble check with water but...just prepping mentally now. Thankfully I at least have the mount/dismount order and torque specs for bolts, plus bootlegged manuals. -
We used a 2 ton on a isx. I wouldn't try it with one of those foldable deals. Even with the tire off you have to extend it out pretty far. Not sure of the weight on a isx,but we on the verge of tipping.
When the old one came off I was on the back while jacking it up. The guy helping pushed it clear till we could let it down some. We called for back up reinstalling.
A little pricy, but an investment in tools is never wasted money.
http://www.harborfreight.com/1-ton-capacity-telescoping-gantry-crane-62510.html -
