How Do You Figure Fuel Surcharge?
Discussion in 'Ask An Owner Operator' started by thiczle, Feb 8, 2022.
  1. thiczle
    thiczle Bobtail Member
    12
    10
    Feb 18, 2019
    Hey everyone. I am trying to understand the fuel surcharge and how to come up with one.. i see companies using $1.50 gallon base, and having fuel charges of up to 40% in some cases. my question is- when i figure out my surcharge do i also use the $1.50 base, or use the cost of fuel when i first started?
  3. kemosabi49
    10,632
    45,527
    Jan 13, 2013
    SW Arkansas
    Call OOIDA. They can show you how it is done.
  4. Ridgeline
    22,385
    116,235
    Well it is simple to figure out if you know what your average mpg is.
    this is per mile cost to add into the rate.
    so … let’s say it is an average 6.8mpg.
    fuel is at $3.45 a gallon.
    I used $1.30 for the base price for fuel so
    3.45 - 1.30 = 2.15
    2.15 / 6.8 = 32¢ is added into the rate.
    if you use the industry standard, then you would use 6mpg and $1,25 base price.
    but that’s all dependent on how you manage your fuel in your budget.
    oh and if a carrier is giving $1.50 as their base, they are cashing in on 25¢ on you.
  5. skallagrime
    skallagrime Road Train Member
    3,856
    9,942
    Apr 10, 2012
    Indiana
    I must be an idiot, this "base" #, never heard of it, why is that being deducted at all?
    Ehhh. Nm, its a dumb holdover "because weve always done it this way" and a way to prevent shippers from paying the real cost of fuel
  6. Ridgeline
    22,385
    116,235
    Well, you’re not an idiot.
    First it has been called “base cost” from when it was created, it is the typical cost of fuel and set at $1.25. I use the term so as habit.
    you deduct it because it gives you the actual difference for the surcharge.
    shippers pay it one way or another, either with a fixed shipping cost and the fuel surcharge or with the increase in rates.
    Beaver9 Thanks this.
  7. wichris
    wichris Road Train Member
    4,279
    8,628
    Jan 17, 2011
    Fuel surcharges were adopted by the ICC after the oil embargo. It was the only way for carriers to increase their "rate" for the higher cost of fuel without ICC approval.
    Leveled off in the early 90's to 1.00-1.15 and that was/still is the base used by most.
  8. skallagrime
    3,856
    9,942
    Apr 10, 2012
    Indiana
    Yeah, i did a bit of digging on how to calculate it and the history, partially id never heard of it because as a single o/o leased on to someone, im not negotiating the contracts. Only last year did i even start digging up my own loads, but thats brokered and fsc is just calculated out using nat fsc numbers.
    That said, it does raise an interesting point that i should probably explore with my boss. I ALWAYS lose money on fuel used vs what he gives me in fsc. This has always kinda rubbed me wrong since our fleet average is such that im not the best mpg, but im above average. I wonder if theyre using this kinda method to figure out fsc. And since 20-30% of fsc is considered "included" in the load pay portion that THEY get a % of, that would explain why ive never broken even, much less made money on fsc.
  9. m16ty
    m16ty Road Train Member
    2,267
    4,948
    Jan 22, 2016
    To add to the confusion, states like KY charge a fuel surcharge on IFTA. What’s that for? KY isn’t buying fuel, you are, but you pay them a surcharge for it. It’s just another way to charge more tax.
  10. wichris
    4,279
    8,628
    Jan 17, 2011
    If you're leased on to a carrier flat rate loads should be broken into linehaul and fsc. Unless you like giving the carrier a % of the fsc that is in the rate. If you're on your own it doesn't matter.
  11. skallagrime
    3,856
    9,942
    Apr 10, 2012
    Indiana
    It is broken down that way on statements, fsc 100%, and % of load, but thats WHY im curious if this base rate is included in linehaul and therefore siphons off a % of the fsc because "its built in as part of the load" which would be true but slightly shady.
