How do you carry a spare tire?
Discussion in 'Ask An Owner Operator' started by Dino soar, Jan 9, 2020.
  1. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    If you pull different trailers how do you carry a spare tire on your truck?
    Is there a tire carrier that you can buy?
    PE_T Thanks this.
  3. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    one company i worked for, had a spare tire carrier mount on the back of the cab. since all the tires were the same size, from that, it did not matter where it got put onto the vehicle.
    in later companies, when ever i'd have a flat, the company called out road service, and i got a brand new tire mounted.
    you'd have to chain it and lock it, to prevent theft if you get one.
    Cabinover101 and Dino soar Thank this.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    If you are pulling different trailers, let the company that owns the trailers deal with it via roadside repair.
    buddyd157 and 201 Thank this.
  5. PE_T
    PE_T Road Train Member
    I’ve seen some companies carry “super single” tires on the side of their truck frame between the fuel tanks and drive tires. Make some measurements to see if you can fit yours.
    The other option is right behind your truck cab, above the cat walk. That’s probably the simplest method for dual single tires. Some Swift trucks have this setup.
    If you do carry tires, make sure your spare tire is no more than 5/32” in tread depth to your truck tires. If you don’t want to worry much about tread depth, you can carry two spare tires, both within 5/32” of one another. However, if you need to replace one tire, you’ll have to replace the other dual single next to it to be able to use your two spare tires together.
    Dino soar Thanks this.
  6. Dino soar
    4,789
    26,858
    Dec 8, 2017
    Well I'm talking about carrying a spare for my tractor so that I won't have to call for road service or at least if I have to call them I won't have to purchase a new tire until I get back.
    Cabinover101 and ZVar Thank this.
  7. Dino soar
    4,789
    26,858
    Dec 8, 2017
    I would like to carry it on the catwalk but I would think you would need some kind of days fixture to put it in.
    Otherwise as the cab on air ride moves up and down the frame stays in the same spot and the tire will rub against the cab.
    PE_T Thanks this.
  8. brsims
    brsims Road Train Member
    5,296
    6,521
    Aug 8, 2009
    Meadville, PA
    I carry my spare tire right above my belt buckle like a real man!
    RubyEagle, booley, magoo68 and 11 others Thank this.
  9. ZVar
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Dino soar and PE_T Thank this.
  10. 201
    201 Road Train Member
    12,047
    24,587
    Apr 16, 2014
    high plains colorado
    Um, unless you have an 1" drive impact with you, and the compressor to run it, good luck. Flat tires are really a thing of the past, and I'd just have an air chuck on your glad hands and air it up to get to a shop.
