How do u power a mini fridge?
Discussion in 'Questions From New Drivers' started by SandyEggo518, Mar 11, 2021.
  1. SandyEggo518
    SandyEggo518 Bobtail Member
    45
    40
    Oct 4, 2018
  3. Wasted Thyme
    7,729
    38,304
    Jan 27, 2020
    GOAT watching
    Depends on the fridge. Truck fridge is usually direct wired and runs off the apu. Dorm fridge is usually plugged in to the inverter.
  4. tarmadilo
    tarmadilo Road Train Member
    1,598
    4,284
    Dec 12, 2018
    I have an RV fridge in my truck, plugs into a 12v “cigarette lighter” style socket. Previously, I had a little dorm fridge that plugged into my inverter.
    Wasted Thyme Thanks this.
  5. SandyEggo518
    45
    40
    Oct 4, 2018
    Ok so there's an apu. Do most trucks have that?
  6. Arctic_fox
    3,869
    19,527
    Sep 16, 2016
    Inverter is how i have always had my fridges powered. My last rig had this setup. Nice HE dorm fridge on a 2500W inverter. Just gotta turn it off if you leave the truck off more then a few hours if you dont want to risk a dead battery.
  7. supersnackbar
    18,606
    44,763
    Aug 19, 2007
    Your Town, USA
    My truckfridge is a direct 12v connection to a factory connector...my company doesn't believe in APU's. It's just wired thru the low voltage cutoff so it won't drain your batteries completely.
    tommymonza Thanks this.
  8. tarmadilo
    1,598
    4,284
    Dec 12, 2018
    That depends on what your company is doing, many do, some don’t.
  9. Harry Flashman
    Harry Flashman Medium Load Member
    510
    1,358
    Oct 4, 2019
    What is the minimum inverter size needed to run a “dorm fridge”?
  10. Arctic_fox
    3,869
    19,527
    Sep 16, 2016
    It depends. How many watts does the fridge pull at peak? how often does it run? are you doing 12V to 120V or a hard wired inverter? How efficent is the inverter?
    As a rule though i wouldnt recomend anything below 800 and a 1500-2000 watt are by far the best bets as they will ensure the fridge wont peg the inverter even if you get a less efficent one as well as let you do stuff like charge a laptop or run a small TV or microwave.
    Harry Flashman Thanks this.
