I need to have an inverter in my truck when I go to Western Express because I have to use a cpap. Does the truck have to be on for the 12v inverter to continually draw power? Also, if I plug in a 12v cooler, how does that stay running 24/7 when the truck is off?
How do inverters work?
Discussion in 'Questions From New Drivers' started by jrm2015, Dec 26, 2016.
[most] Cigarette lighter circuits are always hot. Otherwise a bigger inverter (properly installed) will be connected directly to the batteries and always hot except they will have an on/off switch. Only reason you may need to run the truck is while running something large like maybe a microwave, and the inverter may balk at not having supplemental alternator power. But I suspect a CPAP machine should not be a problem for a smaller inverter and without the truck running, but if your truck is configured to run with fewer batteries, you may not be able to run an inverter long before needing to recharge the batteries.
Houses are on AC current. Automobiles are on DC. Power converters convert the DC current of autos into the AC currentof houses so you can plug in and run household products.
Be warned,without the engine running, power inverters WILL run the batteries down. -
I use a cpap, I run it off a little 175 watt inverter plugged into a cigarette lighter plug, it runs all night with the truck off with no problem, they draw very little power especially if the humidifier is off
