How do I turn off my idle shutdown
Discussion in 'Freightliner Forum' started by dog-c, Mar 24, 2015.
  1. dog-c
    dog-c Road Train Member
    1,852
    1,546
    May 30, 2011
    New York, NY
    Any 2014 cascadia drivers know how to turn this feature off?
    Lost sleep again last nite, if I go into a freight liner dealer are they going to give me crap ? Ty in advance.
  3. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    Do you have Opti-idle?
    Are you the truck owner, lease or a company driver?
    Mikeeee
  4. Grumppy
    3,052
    10,344
    Dec 11, 2010
    West Monroe, La
    I'm not sure if this will help you but here is my experience.
    I have a 2015 Cascadia that we lease from Ryder. The day I picked it up it was hot (June) & I was attempting to idle the truck & I couldn't get it to idle for more that maybe 4 or 5 minutes while trying to move stuff from the old truck to the new one. I went inside & asked them to come show me how to get this new truck to idle. I explained that we didn't have an APU so, I need to be able to idle all night.
    They said I had to turn the key on & let it cycle through its pre-start checks etc, then start it, then use the cruise control to idle it up (900 rpm max) & it will idle. Neither of us could get it to idle for more than a few minutes. After much checking & trouble shooting.... & after specifically saying they could not disable the idle limiter per Ryder rules.... they disabled it.
    Now, mine idles all I need it to, idled up or not.....
    So, will they? I don't know.
    Is it a Frieghtliner warranty issue? I don't know
    Is it a Ryder issue? I don't know.
    I have heard (here at TTR I think) that you're not supposed to low idle these new engines at 500 - 600 rpms. IIRC, you're supposed to idle up these engines at like 800 - 900 rpm if your gonna idle for any length of time.
    Its not a direct answer but I hope this will add something to other answers you get.
    RERM Thanks this.
  5. Pmracing
    6,354
    3,178
    Jan 28, 2011
    I have read here that the idle needs to be higher to keep the cylinders hot enough to keep the piston/ring clearances tight to reduce fuel blow-by into the oil and all resulting subsequent damages.
    Mikeeee
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    You need Detroit Diesel Diagnostic Link 8.0 to change the parameters in the ECM, which may be password protected by the company or Ryder.
    I have my own copy, cost $500 from Detroit plus another $700 for the adaptor, but I own my own truck.
  7. ZhenyaP1991
    ZhenyaP1991 Medium Load Member
    573
    702
    Nov 6, 2014
    Take your fifth wheel puller, jam it between clutch and steering, clutch will be engaged and it won't shut off. Little redneckish but do you want to have a good night of sleep?
    serozhah, dog-c and paul_4lp Thank this.
  8. Grumppy
    3,052
    10,344
    Dec 11, 2010
    West Monroe, La
    On this 2015 Frieghtliner, you can do that but you cant exceed 900 rpms. If you do, after about 30 seconds or so (IIRC), the "check engine" light will come on & start flashing etc, etc. I am not sure it it will shut down etc, cause I got out of the high idle when I did that & the "check engine" light started blinking.
    Having said taht, I've never been able to set the RPMs at a specific range with a stick from the petal to the seat or steering wheel etc. I usually just had to settle for whatever it gave me, as close as I could get it. Usually trying to get a steady 300 rpm difference from a sitting idle of 600 but no more than 900 is hard to set that way..
    I'm not disagreeing with the idea, just saying I never had any luck with that method on this truck.
    Hope this helps :)
  9. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    your copy of diagnosticlink 8 is standard version. you can not change parameters. the professional or engineering versions only can change parameters.
  10. racemaxx24
    racemaxx24 Heavy Load Member
    717
    919
    Jul 4, 2014
    East TN
    Not sure if the bigger trucks are different, however like others have suggested I can override the 5 minute idle limit on my Freightliner M2 by idling it up with the cruise control.
  11. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    *sarcastic comment* work for a better company that donest have ilde restrictions on the truck. but agreed with the rest of the group, idle it up to 7-900 RPM via cruise switch
