How do I override the automatic idle shutoff on a 2022 Kenworth?
Discussion in 'Experienced Truckers' Advice' started by A Bug, Jun 20, 2022.
  1. A Bug
    A Bug Heavy Load Member
    827
    1,575
    Mar 15, 2014
    Sevierville TN
    Truck shuts off after a couple minutes while in park. Pressing the brake or the accelerator will restart the timer for shutdown but then it still shuts off a couple minutes later. Setting the cruise control does not work. Setting the trailer brake and releasing the truck parking brake does not work.
    blairandgretchen Thanks this.
  3. Judge
    84,428
    Go to KW shop tell them to turn the perimeters to 0/turn off idle shutdown.
    Or get a stick on acceleration pedal for now.
  4. A Bug
    827
    1,575
    Mar 15, 2014
    Sevierville TN
    Already tried sticking my winchbar down in there and revved it over a thousand rpm but that does not do it. The shop is the only way to get it done? I am in Atlanta out of hours, First day in this truck and I hate it already.
    Cat sdp, Capacity and Judge Thank this.
  5. blairandgretchen
    13,216
    70,220
    Dec 9, 2011
    South west Missouri
    By selecting a better company pre employment.
    Soltaker, carhaulerjeff, flood and 9 others Thank this.
  6. Judge
    84,428
    I don’t know where the sensor is on those new ones, should have a temp range set, I thought.
    Go get a motel, charge it back to company, tell them to pay or you’ll get a job without a pos truck..
    motocross25 Thanks this.
  7. Trucker61016
    Trucker61016 Road Train Member
    1,077
    3,341
    Sep 18, 2017
    Linville, Va
    Doesn't it have some kind of optimized idle mode ??? Or that it'll idle above certain temperatures??
  8. bryan21384
    bryan21384 Road Train Member
    14,489
    30,983
    Sep 18, 2009
    Memphis, TN
    Push your yellow valve in but leave the trailer breaks set. That's the only way we can idle ours.
    Snow Hater, Northern Nomad and Cat sdp Thank this.
  9. Speedy356
    Speedy356 Medium Load Member
    418
    2,489
    Oct 13, 2021
    Not sure on the new ones, but check the bottom of the drivers side mirror. The sensor should be on the bottom.
    Take a hot hands hand warmer pouch, tape it over the sensor, it should heat up your outside temp gauge and let the truck idle.
    Ours idle above 90 degrees or under 20 degrees without that though!
    Trucker61016 Thanks this.
  10. Capacity
    Capacity Road Train Member
    1,499
    3,116
    Jul 28, 2019
    Neenah Wi
    New truck , no APU , its stuck in.the supply chain , call a cab get a room or call Delta there ready when you are.
  11. desertracer
    desertracer Light Load Member
    66
    99
    Dec 31, 2018
    on kw we used to run with a cat in it just before the truck would shut down the idiot light above the winsheild will blink on and off think it was 5 times on the 5th blink it would shut it down but if you caught the light right befoe the 5th blink just push the clutch down to the floor back up that over rode the shut off good to idle as much as you can
