How do I ground the antennas?
Discussion in 'CB Radio Forum' started by bowlwinkle, Jun 10, 2011.
  1. bowlwinkle
    bowlwinkle Heavy Load Member
    822
    698
    Aug 27, 2008
    Ankeny, IA
    I'm not the most knowledgeable with cb performance, But have been told to make sure the antenna has a good ground. What is the best way to do that?
    I'm currently in a 2010 ProStar, which I have been told does not have the best grounding.
    I want to get a better radio, but want to make sure the antenna system is okay first. I do have a SWR meter, and can tune in the factory antenna fine. But I wanted to put a better antenna on and run better cable, but can't get the SWR close at all with this. I hope someone can helpme here.
    Thanks
  3. Rat
    Rat Road Train Member
    Find the antenna mount or bracket. Run a wire fromt he bracket or mount itself to the nearest peice of metal. If that peice of metal is the door then run a ground from the door to the door pillar so that the hing is not being used as a possible ground. Now make sure the cab is properly grounded to the frame and that the frame has a ground to the batteries.
    You do not want to just run a ground wire/strap from the bracket all the way to the frame or batteries. You want to incorporate all possible metal into the ground system between the antenna and the frame.
    Some guys say that you must use braided ground strapping. I have been using 10 guage wire with very good results. The runs are so short that it really doesn't matter if you use strapping or regular insulated wire.
  4. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
  5. Xcis
    Xcis Medium Load Member
    498
    270
    Jul 9, 2008
    Bridgeport, Pa
    First, what is your current radio, antenna and coax? What is the standing wave ratio [SWR] with the current setup?
    What antenna are you looking to upgrade to? What type of coax do you want to upgrade to?
    Changing coax usually is the least improvement for the money. Unless you are going to run an amplifier that makes an upgrade mandatory, I would not change the coax unless it is in some way faulty.
  6. biged169
    biged169 Light Load Member
    77
    20
    Sep 9, 2010
    Salem, Or
    Do you use one of these? I bought one for my volvo but can not find anything that will fit the threads on this.
  7. Iceratt
    Iceratt Bobtail Member
    34
    May 27, 2005
    I agree with Rat 100%. I find this to be the same in every setup I've ever done also.
  8. windy city preacher man
    windy city preacher man Bobtail Member
    7
    Chicago, IL
  9. handlebar
    handlebar Heavy Load Member
    This should probably be a new thread, but I'll put in a quick reply to the last poster.You could "ground" the antennna mount to the battery, but the DC ground you'd have wouldn't help your RF signal at all. You'd waste the wire and your time doing it. We should start referring to the "ground" that we need at the antenna end of the coax as "counterpoise", or "ground plane" for our discussions. Big difference, and already active in a nearby thread; sometimes more than once daily. Someone sagely gave a link to www.k0bg.com for mobile installation help. Lots of info there, but worth the read. If you search this forum for "copper foil" or "vertical dipole", you'll find two ways I've solved this problem. The tablet I'm posting with now is inserting odd words randomly, us I'll stop for now.73
