How do i clean fuel injector without removing the injector.
Discussion in 'Ask An Owner Operator' started by Ikamob01, Jul 28, 2023.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    How do I clean the fuel injector without removing the injector? I saw something like this;
    But is this possible for a semi-truck?
  3. Big Road Skateboard
    5,687
    29,604
    May 2, 2021
    Is there a reason you think you need to? Cleaning truck injectors isn't really a thing
  4. Ikamob01
    314
    195
    Dec 4, 2021
    I keep getting this code spn 656, 652. and sometimes if I add fuel injector cleaner to my tank, the code will disappear.
    77fib77 Thanks this.
  5. Big Road Skateboard
    5,687
    29,604
    May 2, 2021
    Those are voltage faults IIRC. The additive will have no affect on those.
  6. Ikamob01
    314
    195
    Dec 4, 2021
    codeSPN 651 FMI 7 Engine Fuel 1 Injector Cylinder 1
  7. Big Road Skateboard
    5,687
    29,604
    May 2, 2021
  8. Ikamob01
    314
    195
    Dec 4, 2021
    Cummins engine ISX.
  9. Big Road Skateboard
    5,687
    29,604
    May 2, 2021
    No performance issues? All three codes?
  10. Ikamob01
    314
    195
    Dec 4, 2021
    Nope. no performance issues.
  11. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    fuel injector cleaners work best when everything is new, and you use a cleaner every xx amount of miles.
    as an example i buy all my cars new...at 3,000 miles i add Lucas Fuel Injector cleaner, to a full tank of gasoline.
    and then every 3,000 miles after that, until i sell the car.
    to use a cleaner so late in the game, you really ain't gonna derive any real cleaning benefit.
    gotta be pro-active with that stuff.
    if an injector is giving a code, it's most likely internal to the injector, and if one is throwing a code now, sooner or later they all will.
    i thought that i heard "some guys" change out injectors after xxxxxx amount of miles, get them rebuilt or replaced.
    sorta like a 'preventative PM service'
