How do 1992 peterbilt 379 speedometer/odometers function
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by H2oburymatt, Jun 4, 2017.
  1. H2oburymatt
    H2oburymatt Light Load Member
    154
    52
    Dec 11, 2015
    I recently purchased my 2nd truck a 1992 peterbilt 379. Few minor things left to do before my first employee starts driving the Pete 2 Mondays from now. The pyro and odometer aren't working right. I pulled out the pyro bought a new one and that issue is fixed. It still functioned but the internals and face we're dislodged in the gauge so I decided to replace it and make it right as I know how important this gauge is. I may send the old one out to get repaired and keep on the shelf. The speedo odometer combo part number Q43-6010-005 they no longer make. The speedometer is way off and reads about 45 when traveling 70 mph. I'm going to replace the gauge because of the odometer not working and I'm hoping this will fix my speedo issue as well. Probably not that lucky..The number superceded to 49911RT or 49911. There are a few companies that make these. Amatek does make an analog odometer version. After doing some reading I now know there are at least 3 different types of ways speedos measure speed. Electronic transmission control box is one, electronic sensor somewhere is another and there is even another type as well. Do you guys know which type they used in a 1992 peterbilt? Which type you recommend I replace the bad one with? And how I can fix it if its not just the gauge I'm going to replace? There's a lot here and I truly appreciate any and all input and advice. Thank you!
  3. H2oburymatt
    154
    52
    Dec 11, 2015
    And how does the odometer function that came in my 1992? I feel it's important for me to learn these things so I can stay on top of them.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
  5. H2oburymatt
    154
    52
    Dec 11, 2015
    I installed the new speedometer today and the new one is off the same amount as the old one which needed to be replaced anyway because the odometer was broken. Read about 40 mph while driving 60 mph. There's a what looks like new sending unit/sensor in the box in the truck from the previous owner. My buddy told me if the speedo is reading 40 mph then the sender is working. I matched the 10 switches on the new one to the old one. Next step is to use the instructions and calibrate it properly. My question is if I do that and it's still way off are there any other components than the sensor / sending unit that screws into the back of the Tranny?
  6. Diesel Dave
    8,522
    23,454
    Jan 20, 2010
    Hesperia, Ca.
    Click on the link that @uncleal13 put up. That's the formula you have to follow to set the dip switches on back of the speedometer head. I went through this a year ago. Do your "homework" its all on that LINK .....
    wore out and H2oburymatt Thank this.
  7. AModelCat
    154,362
    What a PITA that was lol
    wore out and Diesel Dave Thank this.
  8. H2oburymatt
    154
    52
    Dec 11, 2015
    I'm going to for sure. I'm wondering if the speedo is reading something even though it's off if that can be anything other than the calibration? Do you guys know how the sending sensors work?
  9. Diesel Dave
    8,522
    23,454
    Jan 20, 2010
    Hesperia, Ca.
    It's not the sensors !!!!!!! It's the dip switches. Previous owner must of done some modification to the truck, anything from tire size, to changing the transmission and/or rear ends ratio. That's why it's of so much. If it has an ECM which I doubt for that year, you need to do the formula to set the dip switches correctly.
    Edit: Even if it had an ECM, you get it close, trust me I tried many times, at the end, it came down to calibrating the dip switches to get it precise.
    wore out Thanks this.
  10. Diesel Dave
    8,522
    23,454
    Jan 20, 2010
    Hesperia, Ca.
    It sure was. I gave up the first time. On the second try it worked like a charm.
  11. 2CAN
    2CAN Medium Load Member
    613
    2,756
    Jan 7, 2010
    Years ago I drove a 92 379 with a DDEC2 there was a toggle switch on the dash tagged "signal". Its was an on/off switch for the odo-speedo. Not sure if you have this or not but it had me scratching my head for a bit
    H2oburymatt Thanks this.
