I have a 98 W900 with an Eaton 18 Speed. How difficult is it to install a PTO for an end dump?
It looks like you can buy all the parts for $2500 but looking online, its says install and parts can be $8500. Is it really a difficult job?
How Difficult to Install PTO for End Dump
Discussion in 'Trucks [ Eighteen Wheelers ]' started by OldRed98, Dec 16, 2021.
No it's not difficult at all, plan on another $500-1000 for various fittings and lines that won't be included in the kit or work. Save yourself some time in the long run and go ahead and put a return line on with a filter so you're setup for lowboys, tankers, walking floor, etc. Other than that figure on one day in the shop you can do it by yourself, but a second set of hands if nothing else but tool runner makes it worlds easier. We typically quote customers 8 hours labor for an install.
Thanks Man. I have a tandem with an Eaton trans and just looking at the PTO setup, it looks pretty straight forward. Mainly fitting and running lines and running the box to the cab . I just wanted to make sure before I decided to try it myself. People online where talking about moving fuel tanks and I couldn't figure out why.
Its hard to find a good shop that can get you in here in Colorado. Plus I really don't want to spend $8500 for a PTO.Bean Jr. and JDHIGGINS44 Thank this. -
Yeah that's outrageous. Be sure to put shut off valves on your tank and I suggest using JIC fittings everywhere you can instead of pipe thread. Other than that if you can service / grease your own truck you can handle it.
Caterpillar Cowboy and OldRed98 Thank this. -
Your getting scammed by that shop. The shop that did mine only charged me $4600 and that included the saddle tank, 55 gallons of fluid, all the lines, fittings a new clutch brake pad and new transmission fluid because they had it open anyway.
OldRed98 Thanks this. -
Not a huge deal. If you're OCD like me it takes a little extra time & effort to get the hose routing looking good.
X2 on JIC fittings. Hell I'd do ORB on the valve, pump and tank fittings too.OldRed98 and Caterpillar Cowboy Thank this. -
Just make sure and pay attention setting the pto lash
dirthaller, OldRed98, Last Call and 1 other person Thank this. -
