How could this happen? And how much to fix? Torn out glad hands
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by LPM, Feb 1, 2024.
  1. LPM
    LPM Bobtail Member
    Feb 1, 2024
    I dropped off a load in the yard and disconnected the glad hands and plug, and I know that I put them back in the stowage.
    I was driving bobtail on the highway and I heard a great big boom and this is what happened:
    I don't think this is my fault.
  3. JB7
    JB7 Medium Load Member
    648
    900
    Dec 13, 2022
    Laurel, MD
    Either one of the air lines or light cord came loose and wrapped around the driveshaft or dropped onto the road and the left front tandem wheels ran over it and yanked it all out. So you will need the air lines and light cord, maybe a tractor protection valve. The 2 holes next to the cord socket, the ends might be able to be removed with an extractor and new air lines attached if the valve is not cracked, broken or threads damaged.
    Crude Truckin' and BoxCarKidd Thank this.
  4. Opus
    114,911
    And it is your fault
  5. tscottme
    tscottme Road Train Member
    The gear that suspends the air lines/electrical, often from a crossbar on the back of the sleeper, may have broken and that allowed one or more of the lines to fall onto the road or get tangled around the drive shaft. I've had the little spring clip that connects to the spring break a couple of times over the years. That's my guess.
  6. OLDSKOOLERnWV
    17,814
    268,544
    If they got wrapped around the driveshaft, there should be visible evidence of where they whipped the piss out of the frame rails. Most likely got under a drive tire and flew out the back like a snake that hit a live wire….
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    I wrapped some around the driveshaft on a similar Shaker. The pogo stick was broke. Everybody else drives it like this so it will be OK right? WRONG! It took awhile to get all that junk off the yoke. It also pulled all that stuff off the cab. You are lucky there is not more damage.
    Flat Earth Trucker, W923 and Last Call Thank this.
  8. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
  9. Last Call
    Last Call Road Train Member
    7,568
    45,898
    Mar 15, 2021
    This ^^^^^^^
    At least 250 probably cloeser to 400
    And Yes it’s your fault
    Opus Thanks this.
  10. AModelCat
    154,482
    Called "#### happens"
  11. M22 rockcrusher
    M22 rockcrusher Road Train Member
    1,237
    3,878
    Nov 21, 2020
    What's the other two electrical sockets on the back sleeper wall for.
    Last Call Thanks this.
