How can i tell if my tires have been properly balanced?
Discussion in 'Ask An Owner Operator' started by Mountaintrucker4302, Dec 4, 2020.
  1. Mountaintrucker4302
    Mountaintrucker4302 Light Load Member
    215
    432
    Sep 21, 2015
    GA
    I just put on a couple of new steer tires and i told them to do balancing too but im not sure if they did. My truck begins shaking a lot for a couple minutes when i go over 70 mph and im wondering if the new tires are the cause. I can feel it in the steering wheel go left to right like the tires r wobbling? Any help is appreciated.
  3. OldeSkool
    OldeSkool Road Train Member
    1,642
    4,434
    Jul 17, 2018
    New Hampshire
    The first thing I would check is make sure they got the lug nuts tight. It doesn’t sound like they got it balanced right though if it’s at that high of speed. Did they use actual weights on the rims or just throw in a bag of beads or something?
    Mountaintrucker4302 Thanks this.
  4. Dale thompson
    5,101
    42,224
    Nov 20, 2013
    commerce twp,mi
    Need more information does the wobble go away after a couple of minutes? Many possibilities make a remote diagnosis difficult at best. Try to describe everything to narrow down the guessing.
  5. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    If you got a shake that wasn’t there before they messed something up.
  6. Lyle H
    Lyle H Road Train Member
    1,289
    2,931
    Apr 16, 2014
    I would suggest that you CALL THE PEOPLE THAT MOUNTED THEM.
    Ask them the same question.
    Mountaintrucker4302 and OldeSkool Thank this.
  7. Rideandrepair
    17,204
    55,809
    Aug 8, 2015
    You can check the balance by jacking the front end up, spin the tire. Mark where it stops at the bottom. Do this a few times. If it always stops in the same place. It’s out of balance. Heavy spot will be on the bottom. I’d check the tie rods, drag link, wheel bearing end play, king pins, spring bushings, if it still does it after balancing. Have the rims checked for being slightly bent. Common problem on aluminum steers. Also have new tires checked for out of round, Both can be done while jacked up on vehicle, by spinning the wheel/tire, while placing a stationary object against the tire tread, and the bead of the rim. Or while on the balancing machine. Equal tire beads work good, I prefer them over weights. Over time tire changes as it wears. Balancing beads, or equal, changes with it. Same idea as Centramatics. Much cheaper.
  8. Tug Toy
    Tug Toy Road Train Member
    6,932
    72,425
    Jul 4, 2015
    Corn field
    All very good information but the person asking this question has no ability to Jack up a semi truck. Otherwise they would already know the answer to there question.
  9. Midwest Trucker
    5,871
    21,125
    Aug 31, 2018
    Hopefully one isn’t out of round. Did it not shake prior to the new steers? We’re new steers the ONLY thing that changed?
    If so I’d get them rebalanced and if it still shakes then you got a bad tire unfortunately.
  10. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Sure sounds like they " buffaloed" the balance job,provided your alignment was good and old tires, not just "worn into place". Maybe a weight fell off .Sometimes you get a "tar" that is a real mofo to balance. Maybe they thought it was "close enough".
  11. Mountaintrucker4302
    215
    432
    Sep 21, 2015
    GA
    Yes the new tires were the only thing that changed. It was done at a ta, i will just have to stop at at another location and try to get them rebalanced i guess.
    Rideandrepair Thanks this.
