How can I scale 45900 LBS on van
Discussion in 'Ask An Owner Operator' started by Peyton2Marvin, Jan 30, 2018.
  1. Peyton2Marvin
    Peyton2Marvin Light Load Member
    76
    41
    Oct 18, 2017
    Hello everyone
    I am interested in hauling car parts for BMW but they load the pallets to max and must be able to scale 45900 pounds.
    I know they move them and up until recently they did a lot of business with landstar owner ops.
    Are there special trailers that haul them? I spoke with the shipping manager and he said he sees wabash regular dry vans do them but doesn’t do much more about trucking specs
    Do I have to find a special trailer or what is the deal? Lighter tractor? We run cascadias
  3. Jacoooooooo
    Jacoooooooo Heavy Load Member
    742
    1,049
    Oct 20, 2013
    Lighter tractor, quarter tanks
    Big_D409 Thanks this.
  4. longbedGTs
    longbedGTs Heavy Load Member
    974
    717
    Texas
    Maybe you could look into the specs for the Cascadias Prime uses to haul heavy loads. They have a shorter nose and smaller sleeper. They have the vents on the sides of the hood whereas the regular Cascadias don't.
    Mooseontheloose Thanks this.
  5. Scooter Jones
    Scooter Jones Road Train Member
    9,551
    19,977
    Apr 19, 2011
    I have a Volvo 670 & Utility 53' dry van. My empty weight with 1/2 tanks is right at 32,500.
    TallJoe Thanks this.
  6. TallJoe
    TallJoe Road Train Member
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    100% the same by me. Well....I weigh 265 lbs though so I might be a bit heavier. .
    whoopNride and Scooter Jones Thank this.
  7. BigGee
    BigGee Light Load Member
    160
    79
    Nov 19, 2007
    Down South
    Places like swift,schneider and other megas order lightweight trucks and trailer for accounts like that.
  8. Cattleman84
    Cattleman84 Road Train Member
    9,871
    70,312
    Nov 1, 2017
    The Sticks, Idaho
    My company runs Cascadias and Volvos with Wabash reefers and we regularly put 46k in the box (both refrigerated as well as non-refrigerated). Just have to make sure you know how to distribute the load right and how to set your trailer tandems properly... Empty I weight 33,200 max... That's fully fueled (truck 200 gal. and reefer 60 gal.), all my crap, tools, jumper cables, tire chains, load-locks, ECT. It will also help if you have your steer axle setup to legally take 12,500... I often with heavy loads run about 12,200 on my steer.
    mhyn, Hammer166, Peyton2Marvin and 2 others Thank this.
  9. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    I agree with being able to max out the front axle makes it very easy. The right front tires can get you legal at 14000 on front axle in most states.
    Cattleman84 Thanks this.
  10. TallJoe
    7,490
    16,271
    Apr 12, 2016
    Chicagoland
    Volvo 670 manufacturer's max weight on steers is 12500 lbs.
  11. Cattleman84
    9,871
    70,312
    Nov 1, 2017
    The Sticks, Idaho
    Yeah but to haul 46k to 46.5k you don't need to have those really fat steer tires that will let you go to 14k steer weight... Just need to be able to get 12.5k on it and it can easily be done... Unless of course you have a fairly heavy light-weight
    Oldironfan Thanks this.
