How can I increase power to my Detroit 11.1L S60 (350 HP rated) Series engine
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ivesti, May 29, 2021.
  1. p608
    p608 Road Train Member
    2,181
    2,991
    Nov 10, 2016
    600 hp and 1600 ftlbs of torque is nothing to make a video about.
    Rideandrepair Thanks this.
  3. jamespmack
    213,427
    Serious Sixty is what you need to Google with location I provided. He 100% can make a 11.1 run. I would try it before spending all the money these guys are proposing.
    Rideandrepair and Swine hauler Thank this.
  4. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    Can get over 500 out of 11.1 with program and turbo
    lwlevens and Rideandrepair Thank this.
  5. Brandt
    Brandt Road Train Member
    4,409
    5,945
    Sep 17, 2012
    They can do more with newer Detroit S60. They can do 1,000HP with 6NZ cat engine. The limit is more on how much money someone wants to spend
    Rideandrepair and jamespmack Thank this.
  6. jamespmack
    213,427
    No a DDec2 is a prom. Programmable read only memory. Its a chip like early gm cars and trucks. Your early GMs with the computer controlled quadrajet is DDC software. You actually can interface with a laptop and adjust and control the carb. Except no one had laptops back then. If you wanna spend the money, you can do neat stuff with them. But now it's still old tech.
    DDec3/4 is Programmable.
  7. Big Road Skateboard
    5,691
    29,647
    May 2, 2021
    Yes, you are correct. Post DDEC 2 would be DDEC 3 and 4. Plug and play options are available for those. DDEC 2 can be tuned but ECM would have to be sent in.
  8. ivesti
    ivesti Bobtail Member
    5
    10
    May 29, 2021
    @jamespmack - I found the guys, will definitely give them a call, thank you.
    The engine again is year 1997 11.1L and the ECM is actually a DDEC 4 from a 12.7, it's just rated at 350 HP.
  9. ivesti
    5
    10
    May 29, 2021
    The cylinder stroke for the 11.1 is 5.47 in (139 mm), while for 12.7 is 6.30 in (160 mm).
    That would mean that I would also have to change the crankshaft to a 12.7 one?
    The cylinder bore is the same on both engines: 5.12 in (130 mm).
  10. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    I don't know anything about the series 60 or the difference from 12.7 to 11.1, but if the larger engine has a longer stroke doesn't that mean that the block itself is different?
    If you put a different crankshaft in and you have a longer stroke what will keep the Pistons from hitting the valves?
  11. jamespmack
    213,427
    He will get you safely more power. Your not gonna get 500. His work is proven. You will be happy.
