Hotshot Trailer - How are you securing your loads?
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Motoz13, Mar 2, 2012.
  1. Motoz13
    Motoz13 Bobtail Member
    10
    San Diego, CA
    Did some searching and struggling to find what I'm looking for.
    I have a 40' flatbed gooseneck with a 5' dovetail.. It has the side rails that I can use chains and ratchet straps, but no built in winches like semi trailers have.. Are you guys just using 2" ratcheting straps like this ( http://www.uscargocontrol.com/Ratch...atchet-Straps/Ratchet-Strap-2x27-w-Flat-Hooks ) or do you add some weld on winches and get the 4" straps to use with those?
  3. Motownfire
    Motownfire Light Load Member
    285
    58
    Nov 17, 2010
    The Great State of Texas
    I have (15) 4" winches that are on a sliding rail on the drivers side. 1 is on a short (about 1') rail between the axles, 5 are behind the axles and 10 are in front of the axles.
    I have seen a lot of trailers with the winches welded on the trailer. My personal preference is to have them on the sliding rail so I can position the winches where I need them for any given load.
    I also carry (6) 20' 3/8" Grade 70 chains and (6) ratcheting binders.
    I have about (30) strap protectors that I made from 5" fire supply hose.
    I would forget about the 2" straps and go with 4" straps in my personal opinion.
    I hope this helps you out. Take care.
  4. me only
    me only Medium Load Member
    309
    85
    Nov 9, 2011
    buford ga
    ive got portable winch on my trailer when i need them .
  5. leadfoot80
    leadfoot80 Light Load Member
    199
    34
    Feb 17, 2012
    S.E. WY
    What do you use otherwise?
  6. me only
    309
    85
    Nov 9, 2011
    buford ga
    a lot of chaining for me .ill use 4'' straps as needed with ratchet sometimes .
    i move a lot of equipment and cars .
  7. Motownfire
    285
    58
    Nov 17, 2010
    Yes, I used the steel rail. I removed the outside board and welded the rail to the underside of the trailer. If you have the equipment and know how to weld its a simple project. All of the trailer shops wanted around $500 to install the winces and rail, so I installed it myself in about 3-4 hours on a day off.
  8. leadfoot80
    199
    34
    Feb 17, 2012
    S.E. WY
    How do you figure out what you need to have in the way of chains/straps? Did yall just buy them as you discovered you needed them? Or what did you start out with?
  9. Poker Guy
    Poker Guy Bobtail Member
    14
    5
    Mar 4, 2012
    Austin, Texas
    Take the capacity of what you can haul and multiply it by four. For instance, if your trailer capacity is 3 cars, then you will need four straps per car. Total of 12 straps... I hope I answered the question properly. If not..... Im online so let me know if I can help.
  10. me only
    309
    85
    Nov 9, 2011
    buford ga
    8 25ft chains- 6 10ft chains grade 70 3/8''
    8 ratchet binders
    10 4'' straps 30ft
    10 2'' straps 30ft
    12 car straps
    2 tarps 26X8ft drop 18 mill thick
    200 bungies 21''
    50 15'' bungies
    this is what i carry and never ran out .
