Hotshot into canada
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Nedrudt, Sep 23, 2014.
  1. Nedrudt
    Nedrudt Light Load Member
    224
    44
    Nov 10, 2013
    Tucson, Az/Dublin, Oh
    What do you need to go into Canada when your 26k and under? Everything I've seen is for over 26. Thank you
  3. Lite bug
    Lite bug Road Train Member
    1,391
    28,747
    May 3, 2014
    Columbus Ohio
    I think you need Canadian Authority. I have seen good paying freight going there. I have heard trouble finding stuff coming back. You can save time and distance by going over the lake on some runs.
  4. wedge542
    wedge542 Light Load Member
    241
    31
    Aug 13, 2007
    roll tide
    might be diff nowdays but when i was going there you needed all the paperwork you had here plus needed a canadian broker to vouch for you or your co and he signed off on the entry bol, no real prob going in but if your bringing out better have your ducks in a row, we never brought anything out to much a pain but now this was with a refer van not a fb, laws here was wayyyy more strict than up there at least back then.
  5. Nedrudt
    224
    44
    Nov 10, 2013
    There's a bunch of loads going to Toronto. Figured it'd be easy to cross back to buffalo.
  6. Ridgeline
    22,114
    113,316
    It depends on if you have an authority to operate in Canada either through a lease or your own authority. With that, if you are on your own, then you need to fulfill the needs for the Canadian/US customs, which does include some paper work and a bond if I remember right. Outside of that, meeting the insurance requirements for Canada is another thing.
    The broker thing is for the product you are moving, their job is to collect the tariffs and/or import/export fees for the shipment, they have zero to do with you as a carrier. Their relationship is with the people who are exporting the product, no one else.
  7. Lawdog800
    Lawdog800 Bobtail Member
    20
    4
    May 23, 2014
    Detroit, MI
    you will need a C.V.O.R. Canadian Vehicle Operators Registration - Costs $250 takes 8 weeks Also check with the CBSA (Canadian Border Services) go to their website and do a search...the CVOR is through the Ministry of Transportation (MTO)
    I just got my CVOR 2 weeks ago, but my bond keeps getting rejected for a TYPO....be sure everything on your CBSA Application matches EXACTLY...... they rejected mine for a comma between my company name and LLC.... Good Luck
    I am currently running loaded from Metro Detroit down through Ohio and PA up to Buffalo then across Canada home empty. Once the CBSA stuff clears I will run back and forth thru Canada, Making my run a day trip instead of overnight.
  8. Lite bug
    1,391
    28,747
    May 3, 2014
    Columbus Ohio
    Good deal Lawdog!!
  9. Lawdog800
    20
    4
    May 23, 2014
    Detroit, MI
    My Bond was finally accepted and my CBSA Carrier Code came thru. Hauled first "In-Transit" load from MI to NY tonight. Went smooth
