HOTSHOT BED REMOVED
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Okellychris, Dec 24, 2020.
  1. Okellychris
    Okellychris Bobtail Member
    4
    Dec 24, 2020
    I’ve seen 3500 Dually trucks pulling a 35’+5’ trailer with full loads while driving. I’ve seen both with beds and with out. I’m buying a Dually in TX to be an owner operator with in the 65’ rule(not exceed it). Is it a Law that I can not remove the bed on a pick up truck? Yet I’ve seen plenty of 1 ton trucks with out a bed hauling trailers. Covers in Diamond plate and job boxes.
  3. Mach
    Mach Light Load Member
    165
    79
    Nov 19, 2017
    Knoxville Tennessee
    Remove ng the bed simply slows you to pull over the 65' law. At that point your truck is considered a tractor and thus can be up to 75 feet in length. If you plan to stay at the 65' mark, you can keep the bed on or remove it if you prefer. There's no law stating that you have to keep it.
  4. Brandonpdx
    Brandonpdx Road Train Member
    4,184
    3,972
    Dec 27, 2007
    Elkhart, IN
    A pickup box will limit the types of trailers you can pull and the length of the truck. It has to be a gooseneck style trailer to clear the bed sides. With a hauler bed or hotshot upfit like from Hitchcrafters you can pull deckover style trailers with a 5th wheel hitch for more deck space.
  5. Chinatown
    Chinatown Road Train Member
    73,340
    164,837
    Aug 28, 2011
    Henderson, NV & Orient
