For you 26000 guys what is your truck GVWR and trailer GVWR along with load capacity and axle ratings and capacities.
Also what is the truck you use and trailer legnth.
Is there a dispatch service out there?
Hotshot 26000 GVW questions?
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Mid-May Trucker, Dec 20, 2018.
I
Mid-May Trucker Thanks this. -
If trailer is rated over 10,000 lbs (10,001 lbs or more) driver still needs CDL.
Lite bug Thanks this.
Rideandrepair Thanks this.
The thing is, the trailer being over 10,000 lbs does not determine if a CDL is needed. It's total weight over 26,001 to determine that. All a trailer over 10,000 lbs detemains, is if you need a CDL, it must be a class A CDL.
Here is a flowchart from WA, but federal and all other states follow the same determinations.
